http/3 seems to stop working after any kind of reload.
- http/3 works as expe…cted before reloading
- I went as far as v2.0.0 back (thus the two Caddyfiles, see further down) and encountered this issue every time
- Caddy seems to still listen on `udp/443` when it's happening:
```bash
$ ss --listening --udp --processes # -lup
UNCONN 0 0 *:https *:* users:(("caddy",pid=872477,fd=8))
- Verbose `curl -vvv` logs:
```bash
$ curl -vvv --http3 https://localhost
* Trying ::1:443...
* Connect socket 5 over QUIC to ::1:443
* Sent QUIC client Initial, ALPN: h3-29,h3-28,h3-27
* Trying 127.0.0.1:443...
* Connect socket 6 over QUIC to 127.0.0.1:443
* After 150000ms connect time, move on!
* connect to ::1 port 443 failed: Connection timed out
* connect to 127.0.0.1 port 443 failed: Connection timed out
* Failed to connect to localhost port 443: Connection timed out
* Closing connection 0
curl: (28) Failed to connect to localhost port 443: Connection timed out
- <details><summary><b>Verbose caddy logs from console with annotations (// 📌):</b></summary><p>
```json
// 📌 start caddy
{"level":"info","ts":1631424276.233273,"msg":"using adjacent Caddyfile"}
{"level":"warn","ts":1631424276.233972,"msg":"input is not formatted with 'caddy fmt'","adapter":"caddyfile","file":"Caddyfile","line":2}
{"level":"info","ts":1631424276.2348974,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["[::1]:2019","127.0.0.1:2019","localhost:2019"]}
{"level":"info","ts":1631424276.2352147,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc00045f030"}
{"level":"info","ts":1631424276.235942,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1631424276.2359629,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"info","ts":1631424276.2525249,"logger":"pki.ca.local","msg":"root certificate is already trusted by system","path":"storage:pki/authorities/local/root.crt"}
{"level":"info","ts":1631424276.2526367,"logger":"http","msg":"enabling experimental HTTP/3 listener","addr":":443"}
{"level":"info","ts":1631424276.2526562,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/root/.local/share/caddy"}
{"level":"debug","ts":1631424276.252672,"logger":"http","msg":"starting server loop","address":"[::]:443","http3":true,"tls":true}
{"level":"debug","ts":1631424276.25269,"logger":"http","msg":"starting server loop","address":"[::]:80","http3":false,"tls":false}
{"level":"info","ts":1631424276.252697,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["localhost"]}
{"level":"warn","ts":1631424276.2530873,"logger":"tls","msg":"stapling OCSP","error":"no OCSP stapling for [localhost]: no OCSP server specified in certificate"}
{"level":"debug","ts":1631424276.2531059,"logger":"tls.cache","msg":"added certificate to cache","subjects":["localhost"],"expiration":1631461064,"managed":true,"issuer_key":"local","hash":"a186539e15337b0547621156c842d1502a09780d05eb5d36684496f530c1fb84"}
{"level":"info","ts":1631424276.2532187,"msg":"autosaved config (load with --resume flag)","file":"/root/.local/share/caddy/autosave.json"}
{"level":"info","ts":1631424276.2532284,"msg":"serving initial configuration"}
{"level":"info","ts":1631424276.2536077,"logger":"tls","msg":"finished cleaning storage units"}
// 📌 test http/3 connection via curl
{"level":"debug","ts":1631424286.478527,"logger":"tls.handshake","msg":"choosing certificate","identifier":"localhost","num_choices":1}
{"level":"debug","ts":1631424286.4785457,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"localhost","subjects":["localhost"],"managed":true,"issuer_key":"local","hash":"a186539e15337b0547621156c842d1502a09780d05eb5d36684496f530c1fb84"}
{"level":"debug","ts":1631424286.4785507,"logger":"tls.handshake","msg":"matched certificate in cache","subjects":["localhost"],"managed":true,"expiration":1631461064,"hash":"a186539e15337b0547621156c842d1502a09780d05eb5d36684496f530c1fb84"}
// 📌 forcefully reload caddy config via curl
{"level":"info","ts":1631424303.4187894,"logger":"admin.api","msg":"received request","method":"GET","host":"127.0.0.1:2019","uri":"/config/","remote_addr":"127.0.0.1:48794","headers":{"Accept":["*/*"],"User-Agent":["curl/7.78.0"]}}
{"level":"info","ts":1631424303.4197412,"logger":"admin.api","msg":"received request","method":"POST","host":"127.0.0.1:2019","uri":"/load","remote_addr":"127.0.0.1:48796","headers":{"Accept":["*/*"],"Cache-Control":["must-revalidate"],"Content-Length":["399"],"Content-Type":["application/json"],"User-Agent":["curl/7.78.0"]}}
{"level":"info","ts":1631424303.4200108,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
{"level":"info","ts":1631424303.4201722,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000276700"}
{"level":"info","ts":1631424303.4203856,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1631424303.4204006,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"debug","ts":1631424303.4204953,"logger":"http","msg":"starting server loop","address":"[::]:80","http3":false,"tls":false}
{"level":"info","ts":1631424303.4205036,"logger":"http","msg":"enabling experimental HTTP/3 listener","addr":":443"}
2021/09/12 07:25:03 [DEBUG] udp/:443: Usage counter should not go above 2 or maybe 3, is now: 2
{"level":"debug","ts":1631424303.420539,"logger":"http","msg":"starting server loop","address":"[::]:443","http3":true,"tls":true}
{"level":"info","ts":1631424303.420544,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["localhost"]}
{"level":"warn","ts":1631424303.4207737,"logger":"tls","msg":"stapling OCSP","error":"no OCSP stapling for [localhost]: no OCSP server specified in certificate"}
{"level":"debug","ts":1631424303.4207897,"logger":"tls.cache","msg":"added certificate to cache","subjects":["localhost"],"expiration":1631461064,"managed":true,"issuer_key":"local","hash":"a186539e15337b0547621156c842d1502a09780d05eb5d36684496f530c1fb84"}
{"level":"info","ts":1631424303.4208012,"logger":"pki.ca.local","msg":"root certificate is already trusted by system","path":"storage:pki/authorities/local/root.crt"}
2021/09/12 07:25:03 [DEBUG] Fake-closing underlying packet conn
{"level":"info","ts":1631424303.4235258,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc00045f030"}
{"level":"info","ts":1631424303.423664,"msg":"autosaved config (load with --resume flag)","file":"/root/.local/share/caddy/autosave.json"}
{"level":"info","ts":1631424303.4236767,"logger":"admin.api","msg":"load complete"}
{"level":"info","ts":1631424303.427598,"logger":"admin","msg":"stopped previous server","address":"tcp/localhost:2019"}
// 📌 test http/3 connection via curl (no result)
</p></details>
<details open><summary><b>Caddyfile (v2.3.0+):</b></summary><p>
```Caddyfile
servers :443 {
protocol {
experimental_http3
localhost {
tls internal
respond localhost
</p></details>
<details><summary><b>Caddyfile (v2.3.0+) as JSON:</b></summary><p>
```json
"logging": {
"logs": {
"default": {
"level": "DEBUG"
"apps": {
"http": {
"servers": {
"srv0": {
"listen": [
":443"
"routes": [
"match": [
"host": [
"localhost"
"handle": [
"handler": "subroute",
"routes": [
"handle": [
"body": "localhost",
"handler": "static_response"
"terminal": true
"experimental_http3": true
"tls": {
"automation": {
"policies": [
"subjects": [
"localhost"
"issuers": [
"module": "internal"
</p></details>
<details><summary><b>Caddyfile (pre v2.3.0):</b></summary><p>
```Caddyfile
experimental_http3
localhost {
tls internal
respond localhost
</p></details>
Below are 3 different way to reproduce this issue:
1. <details open><summary><b>Case (collapse)</b></summary><p>
- Copy example Caddyfile
- ```bash
$ caddy run
- Test http/3 connection via
```bash
$ curl --http3 https://localhost
# localhost
- Force reload same (json) config via API
```bash
$ curl --silent 127.1:2019/config/ | curl -X POST 127.1:2019/load -H "Content-Type: application/json" -d @- -H "Cache-Control: must-revalidate"
- Test http/3 connection again via
```bash
# curl: (28) Failed to connect to localhost port 443: Connection timed out
</p></details>
1. <details><summary><b>Case (expand)</b></summary><p>
- ```bash
$ caddy run
```bash
# localhost
- Force reload same config via CLI
```bash
$ caddy reload --force
```bash
</p></details>
- ```bash
$ caddy run --watch
```bash
# localhost
- Edit config (e.g. `respond`) and save
```bash
</p></details>
Hope this is has not yet been reported. Otherwise feel free to close this issue.
And despite this bug, Caddy is awesome! :)
~ @IndeedNotJames
