I have started to add the azure blob and have seen that the Open()
function have no Request context, is that right?
package filesystems
import (
"io/fs"
"os"
"path/filepath"
// OsFS is a simple fs.FS implementation that uses the local
// file system. (We do not use os.DirFS because we do our own
// rooting or path prefixing without being constrained to a single
// root folder. The standard os.DirFS implementation is problematic
// since roots can be dynamic in our application.)
// OsFS also implements fs.StatFS, fs.GlobFS, fs.ReadDirFS, and fs.ReadFileFS.
type OsFS struct{}
func (OsFS) Open(name string) (fs.File, error) { return os.Open(name) }
func (OsFS) Stat(name string) (fs.FileInfo, error) { return os.Stat(name) }
func (OsFS) Glob(pattern string) ([]string, error) { return filepath.Glob(pattern) }
This file has been truncated. show original
How can I add something like request ID into the open call?
I assume via ctx
but the fs have another lifecycle then a normal caddy module.
here my fs open snipplet
func (azbfs AZBlobFS) Open(name string) (fs.File, error) {
azbfs.logger.Info("Call Open",
zap.String("requuid", "requuid"),
zap.String("name", name))
credential, err_ndac := azidentity.NewDefaultAzureCredential(nil)
if err_ndac != nil {
azbfs.logger.Error("Provision NewDefaultAzureCredential",
zap.String("requuid", requuid),
zap.String("msg", "Error at NewDefaultAzureCredential"),
zap.Error(err_ndac))
return nil, err_ndac
azbfs.logger.Debug("NewDefaultAzureCredential",
zap.Bool("requuiderr", requuiderr))
client, err_nc := azblob.NewClient(azbfs.AZURL, credential, nil)
if err_nc != nil {
azbfs.logger.Error("Provision NewClient",
zap.String("msg", "Error at NewClient"),
zap.Error(err_nc))
return err_nc
azbfs.logger.Debug("NewClient",
zap.Bool("requuiderr", requuiderr),
zap.String("client", client.URL()))
return nil, caddyhttp.ErrNotImplemented
That’s the debug log which shows the request and directly the fs call which make sense because the fileserver request should get the blob content from azure container.
2024/09/24 20:51:21.937 DEBUG http.handlers.rewrite rewrote request {"request": {"remote_ip": "127.0.0.1", "remote_port": "50068", "client_ip": "127.0.0.1", "proto": "HTTP/1.1", "method": "GET", "host": "localhost:8080", "uri": "/assets/600x400_1.png", "headers": {"User-Agent": ["curl/7.81.0"], "Accept": ["*/*"]}}, "method": "GET", "uri": "/600x400_1.png"}
2024/09/24 20:51:21.937 DEBUG http.handlers.file_server sanitized path join {"site_root": ".", "fs": "my-blob", "request_path": "/600x400_1.png", "result": "600x400_1.png"}
2024/09/24 20:51:21.937 INFO caddy.fs.azureblobfs Call Open {"requuid": "requuid", "name": "600x400_1.png"}
What’s the best way to add some information to the fs module?
Here the full file.
package azureblobfs
import (
"bytes"
"fmt"
"io/fs"
"net/http"
"github.com/Azure/azure-sdk-for-go/sdk/azidentity"
"github.com/Azure/azure-sdk-for-go/sdk/storage/azblob"
"github.com/caddyserver/caddy/v2"
"github.com/caddyserver/caddy/v2/caddyconfig/caddyfile"
"github.com/caddyserver/caddy/v2/caddyconfig/httpcaddyfile"
"github.com/caddyserver/caddy/v2/modules/caddyhttp"
"go.uber.org/zap"
const (
Version = "0.1"
func init() {
caddy.RegisterModule(AZBlobFS{})
httpcaddyfile.RegisterHandlerDirective("azureblobfs", parseCaddyfile)
// Middleware implements an HTTP handler that writes the
// uploaded file to a file on the disk.
type AZBlobFS struct {
fs.StatFS `json:"-"`
AzSA string `json:"azure_storage_account,omitempty"`
AZURL string `json:"azure_url,omitempty"`
AZCont string `json:"azure_container,omitempty"`
AZCred azidentity.DefaultAzureCredential
ctx caddy.Context
logger *zap.Logger
// CaddyModule returns the Caddy module information.
func (AZBlobFS) CaddyModule() caddy.ModuleInfo {
return caddy.ModuleInfo{
New: func() caddy.Module { return new(AZBlobFS) },
// Provision implements caddy.Provisioner.
func (azbfs *AZBlobFS) Provision(ctx caddy.Context) error {
azbfs.ctx = ctx
azbfs.logger = ctx.Logger(azbfs)
if azbfs.AzSA == "" {
azbfs.logger.Error("Provision",
zap.String("msg", "no Azure Storage Account specified (azure_storage_account)"))
//return fmt.Errorf("no Azure Storage Account specified (azure_storage_account)")
if azbfs.AZURL == "" {
azbfs.logger.Info("Provision",
zap.String("msg", "no Azure Storage Account URL specified (azure_url), will use https://{azure_storage_account}.blob.core.windows.net/"))
if azbfs.AZCont == "" {
zap.String("msg", "no Azure Blob Container specified (azure_container)"))
return fmt.Errorf("no Azure Blob Container specified (azure_container)")
if (azbfs.AzSA == "") || (azbfs.AZURL == "") {
return fmt.Errorf("no Azure Storage Account (azure_storage_account) and no Azure Storage Account URL (azure_url) specified")
azbfs.logger.Info("Current Config",
zap.String("Version", Version),
zap.String("azure_storage_account", azbfs.AzSA),
zap.String("azure_url", azbfs.AZURL),
zap.String("azure_container", azbfs.AZCont),
return nil
// Validate implements caddy.Validator.
func (azbfs *AZBlobFS) Validate() error {
// TODO: Do I need this func
return nil
if err_nc != nil {
zap.Error(err_nc))
return err_nc
// ServeHTTP implements caddyhttp.MiddlewareHandler.
func (azbfs AZBlobFS) ServeHTTP(w http.ResponseWriter, r *http.Request, next caddyhttp.Handler) error {
repl := r.Context().Value(caddy.ReplacerCtxKey).(*caddy.Replacer)
requuid, requuiderr := repl.GetString("http.request.uuid")
if !requuiderr {
requuid = "0"
azbfs.logger.Error("http.request.uuid",
zap.Object("request", caddyhttp.LoggableHTTPRequest{Request: r}))
azbfs.logger.Info("Successful Blob Access",
// Download the blob
// Container: craftcmsdev2
// Blob: 600x400.png
blobName := "600x400.png"
get, err_ds := client.DownloadStream(azbfs.ctx, azbfs.AZCont, blobName, nil)
if err_ds != nil {
azbfs.logger.Error("Provision DownloadStream",
zap.String("msg", "Error at DownloadStream"),
zap.Error(err_ds))
return err_ds
downloadedData := bytes.Buffer{}
retryReader := get.NewRetryReader(azbfs.ctx, &azblob.RetryReaderOptions{})
_, err_dd := downloadedData.ReadFrom(retryReader)
if err_dd != nil {
azbfs.logger.Error("Provision downloadedData",
zap.String("msg", "Error at downloadedData"),
zap.Error(err_dd))
return err_dd
err_rr := retryReader.Close()
if err_rr != nil {
azbfs.logger.Error("Provision retryReader",
zap.String("msg", "Error at retryReader"),
zap.Error(err_rr))
return err_rr
// Print the content of the blob we created
azbfs.logger.Info("Blob contents",
zap.String("downloadedData-String", downloadedData.String()))
return nil
// Interface guards
var (
_ caddy.Provisioner = (*AZBlobFS)(nil)
_ caddy.Validator = (*AZBlobFS)(nil)
_ caddyhttp.MiddlewareHandler = (*AZBlobFS)(nil)
_ caddyfile.Unmarshaler = (*AZBlobFS)(nil)
that’s my Caddyfile
auto_https off
filesystem my-blob azureblobfs {
azure_storage_account "default"
azure_url "us-east-1"
azure_container "http://localhost:9000"
servers :8080 {
name main
metrics
protocols h1 h2
#trusted_proxies static private_ranges
:8080
log default {
level DEBUG
output stdout
format console {
time_format iso8601
duration_format ms
route /assets/* {
uri strip_prefix /assets
file_server {
fs my-blob
pass_thru
