FileIndex like Nginx/Autoindex possible?
Hi all,
since some days I’m using caddy as a reverse proxy in my local network, which works really good.
I want also to switch from an existing nginx-docker to caddy, but there is a little challgenge for me.
I need a file index page like in NGinx with AutoIndex (no html page, only listing files in folder).
I know that caddy has the file_server function, but my service, for which I need nginx, cannot handle it.
Is there a possibility inside of caddy to use that index pages like in nginx?
Thanks for help,
Dominik
Search for index and browse here:
Thanks for the information, but with this the internal file_server will be used which is not possible for my use-case :slightly_frowning_face:
Or is there a wrong configuration from my side?
My config looks like:
@sub8 host caddy.xxx.org
handle @sub8 {
root * /static/xxx
file_server browse
But then I got it like this:
Caddy
What I need is the classic like:
Classic
Thanks and best regards,
Dominik
You can provide your custom template for the file listing, so you can design it however you like
