File-server --browse and RPM packages (help) [SOLVED]
Hi, I try to host my own RPM repository using Caddy to serve all files .
After I setup my Caddyfile, and go to my https://repo.website.com I see all files, but clicking on RPMS packages (files) browser return - File not found
Firefox can’t find the file at https://repo.website.com/RPMS/foo-1.2.1.rpm as example.
When I click to others files like *.bz2 or also I try to add *.jpg clicking is working and I enable to view or download the files.
Caddyfile
repo.website.com {
        import logging
        encode gzip zstd
        root * /var/www/repo
        file_server browse
caddy --version
Copr repo for caddy owned by @caddy Index of /results/@caddy/caddy/epel-9-x86_64/
Alma Linux 9.6 x86_64
Thanks!
File not found is 404. You’re getting 403, which usually is permissions related.
Check your RPM file permissions. Make sure the account you’re using to run Caddy can read the RPM files.
Hi thanks dude, now fixed !
