laue727
(Lauer)
#1
Hello I am trying to configure Caddy to work with fcgiwrap
here is what I use on Nginx:
location /cgi/ {
try_files $uri $uri/ $uri.cgi?$args;
root /var/www/cgi;
fastcgi_pass unix:/var/run/fcgiwrap.socket;
include /etc/nginx/fastcgi_params;
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
is any of you able to ‘translate’ this config into the equivalent for caddy ?
If it’s not a PHP app, then you can use reverse_proxy
with the fastcgi
transport:
laue727
(Lauer)
#3
we would like to run some perl scripts inside the folder located at /var/www/html/cgi-bin
www.test.com
root * /var/www/html/www.test.com
cgi.test.com {
root * /var/www/html/cgi-bin
reverse_proxy /bin/perl
fastcgi /var/www/html/cgi-bin/* /bin/perl {
have no idea how to do this…
It’ll probably look something like this:
www.test.com {
cgi.test.com {
root * /var/www/cgi
try_files {path} {path}/ {path}.cgi?{query}
reverse_proxy unix//var/run/fcgiwrap.socket {
transport fastcgi {
[any fastcgi transport options you need]
laue727
(Lauer)
#5
thank you, it worked !
cgi.test.com {
root * /var/www/cgi
transport fastcgi {
split .cgi
I end up putting split .cgi as transport
system
(system)
closed
#6
