This is nitpicking; but the way I have my firefox setup (default under ubuntu), I only see Caddy’s favicon on the “current” tab. It disappears in the inactive tabs. Would be nice to fix it Probably removing transparency?
Oops. How should we fix this? The active tab has a light background, the inactive tab has a dark background. If I do a white fill inside the rhombus, will that cause it to appear properly, you think?
Umm. Right. The parts outside the rhombus transparent, and fill gray (#ccc) maybe? in the rhombus.
I gave it a white fill. Hope that works, I’m not a good icon artist!
Looks good! Thanks.
