caddy/caddy:2.1.1-alpine
using docker:
FROM caddy/caddy:2.1.1-alpine
and docker-compose:
version: '3.7'
db:
# specify container name to make it easier to run commands
container_name: apf_db
restart: always
image: db
build:
context: ./db
env_file:
- ./.env
- network
expose:
- '5432'
# make the Postgres database accessible from outside the Docker container on port 5432
- '5432:5432'
- db_data:/var/lib/postgresql/data
- sik_data:/sik_data
ss:
build:
context: ./ss
- network
container_name: ss
restart: always
env_file:
- ./.env
expose:
- '7000'
- '7000:7000'
graphql:
container_name: apf_graphql
build:
context: ./graphql
- network
expose:
- '5000'
- '5000:5000'
depends_on:
- db
env_file:
- ./.env
command: [
'--connection',
'${DATABASE_URL}',
'--schema',
'apflora',
'--append-plugins',
'postgraphile-plugin-connection-filter,@graphile-contrib/pg-order-by-related,@graphile/postgis,postgraphile-plugin-connection-filter-postgis',
'--jwt-token-identifier',
'auth.jwt_token',
'--default-role',
'postgres',
#'authenticator',
'--jwt-secret',
'${JWT_SECRET}',
'--body-size-limit',
'300kb',
'--cors',
'--disable-query-log',
'--enable-query-batching',
'--retry-on-init-fail',
qgisserver:
#image: camptocamp/qgis-server
build:
context: ./qgisserver
- qgisserver_data:/data
#links:
# - db:db
- '5555:80'
expose:
- '5555'
restart: always
- network
container_name: qgisserver
build:
context: ./caddy
container_name: apf_caddy
- network
depends_on:
- graphql
- qgisserver
restart: always
# original image downgrades user but that seems not to work
# see: https://caddy.community/t/basic-docker-compose-setup-failing/6892/7?u=alexander_gabriel
user: root
- '80:80'
- '443:443'
env_file:
- ./.env
- caddy_certs:/root/.local/share/caddy
- caddy_config:/root/.config/caddy
db_data:
sik_data:
caddy_certs:
caddy_config:
qgisserver_data:
network:
a docker droplet on digitalocean.com (ubuntu I think)
# see: https://caddyserver.com/docs/caddyfile/concepts
email alex.barbalex@gmail.com
#acme_ca https://acme-staging-v02.api.letsencrypt.org/directory
#debug
api.apflora.ch {
reverse_proxy * apf_graphql:5000 {
header_down Access-Control-Allow-Origin *
ss.apflora.ch {
reverse_proxy * ss:7000 {
header_down Access-Control-Allow-Methods "GET, POST, OPTIONS"
header_up X-Real-IP {http.request.remote}
header_up X-Forwarded-For {http.request.remote}
header_up X-Forwarded-Proto {http.request.scheme}
# caddy docs:
# https://caddyserver.com/docs/modules/http.reverse_proxy.transport.fastcgi
# https://caddyserver.com/docs/caddyfile/directives/reverse_proxy
# example: https://github.com/opengisch/qgisserver-caddy/blob/master/Caddyfile
# nginx example: https://docs.qgis.org/3.10/en/docs/user_manual/working_with_ogc/server/containerized_deployment.html#usable-sample
gisdata.apflora.ch {
reverse_proxy * qgisserver:5555 {
transport fastcgi
Every time I hit https://gisdata.apflora.ch/?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities, a 402 is returned and this error is logged:
"level": "error",
"ts": 1600184605.7592506,
"logger": "http.log.error",
"msg": "dial tcp 172.18.0.6:5555: connect: connection refused",
"request": {
"method": "GET",
"uri": "/?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities",
"proto": "HTTP/2.0",
"remote_addr": "77.57.29.8:55440",
"host": "gisdata.apflora.ch",
"headers": {
"Cache-Control": ["max-age=0"],
"Upgrade-Insecure-Requests": ["1"],
"Dnt": ["1"],
"User-Agent": [
"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/85.0.4183.102 Safari/537.36"
"Accept": [
"text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"
"Sec-Fetch-Mode": ["navigate"],
"Sec-Fetch-User": ["?1"],
"Sec-Fetch-Site": ["cross-site"],
"Sec-Fetch-Dest": ["document"],
"Accept-Encoding": ["gzip, deflate, br"],
"Accept-Language": [
"de-CH,de;q=0.9,en-US;q=0.8,en;q=0.7,es-CR;q=0.6,es;q=0.5,de-DE;q=0.4"
"tls": {
"resumed": false,
"version": 772,
"ciphersuite": 4865,
"proto": "h2",
"proto_mutual": true,
"server_name": "gisdata.apflora.ch"
"duration": 0.001660532,
"status": 502,
"err_id": "846kztqpg",
"err_trace": "reverseproxy.(*Handler).ServeHTTP (reverseproxy.go:411)"
I have tried adding options inside the transport fastcgi part of the Caddyfile. But that did not help and to be honest, I don’t know what is needed as there seem to be reasonable defaults but it is not clear to me whether that means that I skip them completely.
