1. Caddy version:
I am using lucaslorentz / caddy-docker-proxy (GitHub - lucaslorentz/caddy-docker-proxy: Caddy as a reverse proxy for Docker)
Ubuntu HOST using Docker swarm
docker swarm starts caddy
image: lucaslorentz/caddy-docker-proxy:ci-alpine
- app_network
- caddy_data:/data
deploy:
placement:
constraints:
- node.role == manager
replicas: 1
restart_policy:
condition: any
healthcheck.phppointofsale.com:80, http:// {
reverse_proxy 10.0.1.32 10.0.1.33 {
trusted_proxies private_ranges
*.phppointofsale.com:80, *.phppos.com:80 {
reverse_proxy 10.0.1.30 10.0.1.29 {
*.phppointofsalestaging.com:80 {
reverse_proxy 10.0.1.18 10.0.1.17 {
custom.phppointofsale.com:80, custom.phppos.com:80 {
reverse_proxy 10.0.1.25 10.0.1.24 {
feedback.phppointofsale.com:80, feedback.phppos.com:80 {
reverse_proxy 10.0.1.51 10.0.1.52 {
help.phppointofsale.com:80, help.phppos.com:80 {
reverse_proxy 10.0.1.39 10.0.1.40 {
mysql.phppointofsale.com:80, mysql.phppos.com:80 {
reverse_proxy 10.0.1.15 10.0.1.14 {
www.phppointofsale.com:80, www.phppos.com:80, phppointofsale.com:80, phppos.com:80 {
reverse_proxy 10.0.1.45 10.0.1.46 {
www.phppointofsalestaging.com:80, phppointofsalestaging.com:80 {
reverse_proxy 10.0.1.4 10.0.1.3 {
zatca.phppointofsale.com:80, zatca.phppos.com:80 {
reverse_proxy 10.0.1.57 10.0.1.54 {
I am trying to make a default fall back if it doesn’t match any other sites. All traffic routes to healthcheck.phppointofsale.com no matter the domain.
Is there a way to avoid putting :80? I have to do this because my server sites behind cloudflare and load balancer and load balancer is ssl terminated
I just want it to look clean with port. I know I can also do http://, but then I can’t do wildcards.
- Removing healthcheck.phppointofsale.com. I believe it doesn’t like http://
If I remove entire healthcheck, http it routes to other sites well, but then I cannot have a default site
- Tried doing http:// for each site but doesn’t let me did wildcards
