So, I’ve been trying to use caddy to set up a reverse proxy for my Jellyfin server. I followed this tutorial on YT: Full Install of Caddy + DuckDNS + Jellyfin with in Depth Setup for Windows - YouTube
Whenever I run the command “caddy run --config Caddyfile”
Here is the caddy file
domainhere.duckdns.org {
reverse_proxy 192.168.0.187:8096
dns duckdns accesstoken
These same errors repeat over and over again
2023/03/25 17:32:32.542 ←[34mINFO←[0m http.acme_client trying to solve challenge {"identifier": "domainhere.duckdns.org", "challenge_type": "dns-01", "ca": "https://acme.zerossl.com/v2/DV90"}
2023/03/25 17:32:32.580 ←[31mERROR←[0m http.acme_client cleaning up solver {"identifier": "domainhere.duckdns.org", "challenge_type": "dns-01", "error": "no memory of presenting a DNS record for \"_acme-challenge.domainhere.duckdns.org\" (usually OK if presenting also failed)"}
2023/03/25 17:32:32.968 ←[31mERROR←[0m tls.obtain could not get certificate from issuer {"identifier": "domainhere.duckdns.org", "issuer": "acme.zerossl.com-v2-DV90", "error": "[domainhere.duckdns.org] solving challenges: presenting for challenge: adding temporary record for zone \"duckdns.org.\": DuckDNS request failed, expected (OK) but got (KO), url: [https://www.duckdns.org/update?domains=domainhere.duckdns.org&token=accesstoken&txt=hwmbzZ7_503d3JqwBTkXpaE_ewphopVVDAWO7m1b_ys&verbose=true], body: KO (order=https://acme.zerossl.com/v2/DV90/order/2kjKHJhxfJDOILtE971VfA) (ca=https://acme.zerossl.com/v2/DV90)"}
2023/03/25 17:32:32.972 ←[31mERROR←[0m tls.obtain will retry {"error": "[domainhere.duckdns.org] Obtain: [domainhere.duckdns.org] solving challenges: presenting for challenge: adding temporary record for zone \"duckdns.org.\": DuckDNS request failed, expected (OK) but got (KO), url: [https://www.duckdns.org/update?domains=domainhere.duckdns.org&token=accesstoken&txt=hwmbzZ7_503d3JqwBTkXpaE_ewphopVVDAWO7m1b_ys&verbose=true], body: KO (order=https://acme.zerossl.com/v2/DV90/order/2kjKHJhxfJDOILtE971VfA) (ca=https://acme.zerossl.com/v2/DV90)", "attempt": 1, "retrying_in": 60, "elapsed": 3.2490082, "max_duration": 2592000}
v2.6.4
Following the tutorial above, I went to the caddy download page, added duckdns as one of the plugins I would like to use.
I then created a directory called C:\Tools\Caddy. I then renamed the custom exe name to simply caddy.exe. In this same directory I created the Caddyfile (contents listed above).
I then ran “caddy run --config Caddyfile” and got the errors listed in Number 2.
Windows 10.
None
