Failed to Proxypass to Unix Socket
I use SSH tunnel remote forwarder with unix socket as listener in the remote to expose my local port, below is how the command:
ssh -N -R /tmp/dpanel.sock::3000 -i secret dpanel@<MY-TUNNEL-SERVER>
Then, I try to call the socket using simple go script below:
package main
import (
	"context"
	"fmt"
	"io"
	"net"
	"net/http"
	"time"
func main() {
	socketPath := "/tmp/dpanel.sock"
	// Create a custom http.Client
	client := http.Client{
		Transport: &http.Transport{
			// Custom DialContext to connect to the Unix socket
			DialContext: func(ctx context.Context, _, _ string) (net.Conn, error) {
				return net.DialUnix("unix", nil, &net.UnixAddr{Name: socketPath, Net: "unix"})
		Timeout: 5 * time.Second, // Set a timeout for the request
	// Make an HTTP request using the custom client
	// The host in the URL (e.g., "http://localhost") is largely irrelevant
	// when using Unix sockets, but it's required by the http.Request structure.
	// You can use any valid host here.
	req, err := http.NewRequest("GET", "http://localhost/api/data", nil)
	if err != nil {
		fmt.Printf("Error creating request: %v\n", err)
		return
	resp, err := client.Do(req)
	if err != nil {
		fmt.Printf("Error sending request: %v\n", err)
		return
	defer resp.Body.Close()
	// Read and print the response body
	body, err := io.ReadAll(resp.Body)
	if err != nil {
		fmt.Printf("Error reading response body: %v\n", err)
		return
	fmt.Printf("Response Status: %s\n", resp.Status)
	fmt.Printf("Response Body: %s\n", body)
It works as expected, with response from my local service.
Now, what I’am expecting is CaddyServer will also works as my golang app, I use this config below in my Caddyfile:
with-socket.beta.devetek.app/demo {
                 reverse_proxy unix//tmp/dpanel.sock
There is no useful information I found why, I believe Caddy have different behaviour with my golang code, but I didn’t found from any link to mimic my go to caddyfile config.
I install custom caddy with extra plugins from repository Releases · devetek/d-panel-router · GitHub
And running it using systemd
Distributor ID: Ubuntu
Description: Ubuntu 24.04 LTS
Release: 24.04
Codename: noble
Running with systemd 255 (255.4-1ubuntu8.8)
I use normal caddy command:
ExecStart="/usr/local/bin/caddy" run --environ --config "/etc/caddy/Caddyfile"
ExecReload="/usr/local/bin/caddy" reload --config "/etc/caddy/Caddyfile"
Restart=always
RestartSec=10s
User=root
Group=root
; Use a minimal /dev
PrivateDevices=true
ProtectHome=false
; ... except /etc/ssl/caddy, because we want Letsencrypt-certificates there.
;   This merely retains r/w access rights, it does not add any new. Must still be writable on the host!
ReadWriteDirectories=/etc/ssl/caddy /var/log/caddy
Not found any relevant link to resolve this issue
Resolved!, issue from the tunnel
