Failed to load module script:
When running my web project in caddy I get the following error in the browser.
Though I am posting one instance, there are a number of javascript files that give the same error.
“Expected a JavaScript module script but the server responded with a MIME type of “text/plain”. Strict MIME type checking is enforced for module scripts per HTML spec.”
1. Output of caddy version:
v2.5.2
caddy file-server
Windows 10
I am not 100% sure if I “MUST” have a config file and how that should be configured not to have this particular issue.
A point in the right direction would be appreciated
That should work; usually this means that the MIME type couldn’t be detected because your system’s MIME types database is incomplete or missing. I think on Windows, these are extracted from the Registry.
Thanks for the hint Matt.
I checked the reg and found that the Computer\HKEY_CLASSES_ROOT\.js was not set to “text/javascript”.
Changed that and now it works fine.
Thanks again for your quick response, much apprecited.
Excellent. Thanks for following up!
