> command docker exec -it caddy caddy version
On Raspberry Pi 3 with docker.
Raspberry pi 3, docker,
docker-compose -f caddy/docker-compose.yml up -d
version: "3.8"
image: caddy
hostname: caddy
env_file: ../.env
- DOMAIN
- DOMAIN_LOCAL
- ./data:/data
- ./config:/config
default:
external:
portainer.{$DOMAIN} portainer.{$DOMAIN_LOCAL} {
reverse_proxy {$IP_PORTAINER}:9000
home.{$DOMAIN} home.{$DOMAIN_LOCAL} {
reverse_proxy {$IP_HOMEASSISTANT}:8123
How do I integrate fail2ban into CaddyV2 docker image?
None
Read this:
Answer seems unclear. I’m not sure if it’s do-able or not?
Can someone explain if it’s possible to run fail2ban either inside or alongside the caddyV2 docker image? Maybe another image should be created that has this integrated as it’s a very popular security tool?
