Fail to renew ssl cert
I am using Caddy v1.0.4. When trying to renew the ssl cert, I received the following message:
2020/07/08 07:38:22 [INFO] [milanolarry.tk] acme: Obtaining bundled SAN certificate
2020/07/08 07:38:23 [INFO] [milanolarry.tk] acme: Obtaining bundled SAN certificate
2020/07/08 07:38:25 [INFO] [milanolarry.tk] acme: Obtaining bundled SAN certificate
2020/07/08 07:38:26 [INFO] [milanolarry.tk] acme: Obtaining bundled SAN certificate
2020/07/08 07:38:28 [INFO] [milanolarry.tk] acme: Obtaining bundled SAN certificate
2020/07/08 07:38:29 failed to obtain certificate: acme: error: 429 :: POST :: https://acme-v02.api.letsencrypt.org/acme/new-order :: urn:ietf:params:acme:error:rateLimited :: Error creating new order :: too many failed authorizations recently: see Rate Limits - Let's Encrypt, url:
The problem is I had attempted a renewal almost 13 hours ago and, of course, it failed. Anything wrong? Thanks.
Hey @milanolarry,
That’s a pretty old version of Caddy. I’d recommend upgrading to Caddy 2, it should fix the problem. But you’ll just need to wait for the rate limits to unwind.
Thanks. How long do I need to wait for the rate limits to unwind?
You can refer to their documentation here: Rate Limits - Let's Encrypt
