If you want to use the URL shortener service YOURLS, you have to use a special configuration in order to make it work with Caddy 2.
Here’s the minimum Caddyfile configuration you will need :
domain.com {
root * /var/www/yourls
route {
try_files {path} {path}/index.php yourls-loader.php
php_fastcgi unix//run/php/php-version-fpm.sock
Don’t forget to change the configuration :
domain.comwith your domain name ; -
/var/www/yourlswith the actual path where you installed YOURLS ; -
unix//run/php/php-version-fpm.sockwith the correct php-fpm sock path.
