I have an older GNU mailman installation that should still be available if if served via caddy. As all the mailman stuff is CGI, I used xcaddy to build a version of caddy with cgi support:
xcaddy build --with github.com/aksdb/caddy-cgi/v2
Then I customized the caddy systemd service file using:
sudo systemctl edit caddy.service
to add the following as override parameters:
ExecStart=
ExecReload=
ExecStart=/usr/local/bin/caddy run --environ --config /etc/caddy/Caddyfile
ExecReload=/usr/local/bin/caddy reload --config /etc/caddy/Caddyfile
Group=www-data
SupplementaryGroups=list
This points to the locally installed caddy in /usr/local/bin as well as setting the primary group of the caddy server to www-data (default for my old Debian installation for the apache server, required for mailman). I also set a supplementary group of list to be able to access the mail archives. I use the following snipped In my Caddyfile:
handle /cgi-bin/* {
cgi /cgi-bin/mailman/admin* /usr/lib/cgi-bin/mailman/admin {
script_name /cgi-bin/mailman/admin
cgi /cgi-bin/mailman/admindb* /usr/lib/cgi-bin/mailman/admindb {
script_name /cgi-bin/mailman/admindb
cgi /cgi-bin/mailman/confirm* /usr/lib/cgi-bin/mailman/confirm {
script_name /cgi-bin/mailman/confirm
cgi /cgi-bin/mailman/create* /usr/lib/cgi-bin/mailman/create {
script_name /cgi-bin/mailman/create
cgi /cgi-bin/mailman/edithtml* /usr/lib/cgi-bin/mailman/edithtml {
script_name /cgi-bin/mailman/edithtml
cgi /cgi-bin/mailman/listinfo* /usr/lib/cgi-bin/mailman/listinfo {
script_name /cgi-bin/mailman/listinfo
cgi /cgi-bin/mailman/options* /usr/lib/cgi-bin/mailman/options {
script_name /cgi-bin/mailman/options
cgi /cgi-bin/mailman/private* /usr/lib/cgi-bin/mailman/private {
script_name /cgi-bin/mailman/private
cgi /cgi-bin/mailman/rmlist* /usr/lib/cgi-bin/mailman/rmlist {
script_name /cgi-bin/mailman/rmlist
cgi /cgi-bin/mailman/roster* /usr/lib/cgi-bin/mailman/roster {
script_name /cgi-bin/mailman/roster
cgi /cgi-bin/mailman/subscribe* /usr/lib/cgi-bin/mailman/subscribe {
script_name /cgi-bin/mailman/subscribe
handle_path /pipermail* {
root * /var/lib/mailman/archives/public
handle_path /images/mailman* {
root * /usr/share/images/mailman
