Example: mTLS with Basic Auth fallback
This is a config created according to the post here that allows for basic auth to be used as a fallback when an mTLS client cert is not presented.
# This matcher checks for the presence of an mTLS client cert
(missing_mTLS_cert) {
    @missing_mTLS_cert {
        expression {tls_client_subject} == null
(admin_user) {
    # user: test, pass: test
    test JDJhJDEwJGdtd01Gc0ttWUJFaVZEY0hpMGIwTmVSb2lwalpSUFl1NnouT2VjeTZwOTZCNDRuWVA4Ti5h
(guest_user) {
    # user: guest, pass: test
    guest JDJhJDEwJGdtd01Gc0ttWUJFaVZEY0hpMGIwTmVSb2lwalpSUFl1NnouT2VjeTZwOTZCNDRuWVA4Ti5h
(private_auth) {
    import missing_mTLS_cert
    basicauth @missing_mTLS_cert {
        import admin_user
(guest_auth) {
        import admin_user
        import guest_user
# use this import if you want to always require mTLS certs to get in
(mTLS_required) {
        client_auth {
            mode require_and_verify
            trusted_ca_cert_file /path/to/cert/cert.cer
# use this import if you want to be able to fallback to basic auth
(mTLS_optional) {
        client_auth {
            mode verify_if_given
# this one has optional mTLS
example.com {
    reverse_proxy localhost:9090
    import mTLS_optional
    import private_auth
# or try it with required mTLS
required.example.com {
    reverse_proxy localhost:9091
    import mTLS_required
