Events exec handler - permission denied
I’m trying to launch a script every time a certificate is obtained/renewed. I’m using the events.handlers.exec module for that → JSON Config Structure - Caddy Documentation
I always get some permission error, which is strange since the folders are all owned by caddy:caddy and I even tried with a “tmp” subdirectory which has 777.
mai 03 08:39:33 pandabaer.lan.somebear.space caddy[92368]: {"level":"debug","ts":1714718373.5122151,"logger":"events","msg":"event","name":"cached_managed_cert","id":"305e9b1c-38fa-4c93-81b4-77c7756b4af6","origin":"tls","data":{"sans":["atest6.lan.somebear.space"]}}
mai 03 08:39:33 pandabaer.lan.somebear.space caddy[92385]: /var/lib/caddy/tmp/dscript.sh: line 3: ./certpath-test: Permission denied
mai 03 08:39:33 pandabaer.lan.somebear.space caddy[92368]: {"level":"error","ts":1714718373.514313,"logger":"events.handlers.exec","msg":"background command failed","error":"exit status 1"}
I’m using Arch with a binary compiled via xcaddy to add the events.handlers.exec module.
I’m running it through the unit file.
# /etc/systemd/system/caddy.service
# caddy.service
# for your installation.
Type=notify
# The configuration below serves a welcome page over HTTP on port 80.
# domain name.
# https://caddyserver.com/docs/caddyfile/concepts#addresses
	# Restrict the admin interface to a local unix file socket whose directory
	# is restricted to caddy:caddy. By default the TCP socket allows arbitrary
	# modification for any process and user that has access to the local
	# interface. If admin over TCP is turned on one should make sure
	# implications are well understood.
	admin "unix//run/caddy/admin.socket"
	email "postmaster@somebear.space"
	cert_issuer acme
	log log0 {
		output stdout
		level DEBUG
	events {
		on cert_obtained exec /var/lib/caddy/tmp/dscript.sh {event.data.identifier} {event.data.storage_path}
https://atest6.lan.somebear.space {
		#on_demand
		issuer acme {
			dir https://pki.lan.ursidae.space:10443/acme/acme/directory
			trusted_roots /etc/caddy/certs/root_ca.crt
			alt_tlsalpn_port 9443
	encode gzip zstd
	respond "it's something"
Here is the script I’m currently using and the permissions of the directory
/var/lib/caddy
root@pandabaer pandabaer.lan.somebear.space~caddy # ls -la
total 48
drwxr-x---  8 caddy caddy 4096  3 mai   08:36 .
drwxr-xr-x 59 root  root  4096 19 avril 16:18 ..
drwx------  3 caddy caddy 4096  3 mai   08:36 .config
drwx------  4 caddy caddy 4096  3 mai   08:19 .local
drwx------  3 caddy caddy 4096 12 nov.  10:55 acme
-rw-------  1 caddy caddy 4308 16 avril 19:29 autosave.json
drwx------  3 caddy caddy 4096 12 nov.  13:56 certificates
-rw-------  1 caddy caddy   36 16 avril 19:24 instance.uuid
-rw-------  1 caddy caddy  112  2 mai   20:00 last_clean.json
drwx------  2 caddy caddy 4096  3 mai   08:32 locks
drwxrwxrwx  2 caddy caddy 4096  3 mai   08:31 tmp
Also here is the script - it does not do much currently because I’m trying to find out how to copy the certificate from one place to another right now, so it’s just for testing the output currently and to see if I can get it to output to another file.
#!/bin/bash
echo $1 $2 > ./certpath-test
Thank you,
Is certpath_test executable?
That’s the file I’m trying to create under “tmp” also the directory has all permissions (777).
root@pandabaer pandabaer.lan.somebear.space/var/lib/caddy/tmp # ll
total 4
-rwxrwxrwx 1 caddy caddy 27  3 mai   17:21 dscript.sh
But that’s dscript.sh. What is certpath_test?
That is just the file I want to create for a test with dscript.sh.
Here is the contents of dscript.sh :
