Event dispatching system for Caddy
@francislavoie , on Caddy in Docker - can another container read the certificates? you said:
I’m working on an event dispatching system for Caddy which should eventually make it possible to copy certs for a domain to a well-known location when a cert is issued or renewed, but I don’t have a timeline for when it’ll be ready.
Any news about this?
Yep, see here: Global options (Caddyfile) — Caddy Documentation
I put
        #acme_ca https://acme-v02.api.letsencrypt.org/directory
        events {
                on cert_obtained exec /root/certificate_obtained.sh {event.data.identifier} {event.data.certificate_path} {event.data.private_key_path}
                output file /var/log/caddy.log
on Caddyfile and /root/certificate_obtained.sh contains
#!/bin/ash
if [ "$#" -eq 0 ]
then
  echo "No arguments supplied" > /root/log.txt
  exit 1
fi
echo "`date "+%Y-%m-%d %H:%M:%S"` $1" >> /root/log.txt
echo "`date "+%Y-%m-%d %H:%M:%S"` $2" >> /root/log.txt
echo "`date "+%Y-%m-%d %H:%M:%S"` $3" >> /root/log.txt
just to see if script is being called and his parameters.
Nothing on log file and no /root/log.txt is created (script is not being called?).
I am using Caddy with caddy-dns/cloudflare and mholt/caddy-events-exec
Are you actually running Caddy as root or is it running as a systemd service?
You didn’t fill out the help topic template so I’m missing a lot of context here. Please fill out the template if you need help.
I just created a simple Caddy module to publish events to a Kafka topic, might be helpful for you. It isn’t certificate issuance specific, but you can read the events and fetch the certificates from storage if you want (i.e with a cert_obtained event).
Sorry, I was in a hurry and thought it just add
        events {
to /etc/Caddyfile would be enough to dispatch the shell script.
I will got more information and fill the topic template.
@francislavoie , now I think I have put all the necessary information, please let me know if you need any other information.
I couldn’t get the script to run when Caddy got the certificates.
I didn’t see any error messages.
caddy:~# caddy version
v2.7.3 h1:eMCNjOyMgB5A1KgOzT2dXKR4I0Va+YHCJYC8HHu+DP0=
I’m using an LXC container with Alpine Linux v3.18 running on Proxmox v8.0.4.
       .hddddddddddddddddddddddh.          root@caddy
      :dddddddddddddddddddddddddd:         ----------
     /dddddddddddddddddddddddddddd/        OS: Alpine Linux v3.18 x86_64
    +dddddddddddddddddddddddddddddd+       Host: Nitro AN515-51 V1.22
  `sdddddddddddddddddddddddddddddddds`     Kernel: 6.2.16-8-pve
 `ydddddddddddd++hdddddddddddddddddddy`    Uptime: 1 hour, 11 mins
.hddddddddddd+`  `+ddddh:-sdddddddddddh.   Packages: 84 (apk)
hdddddddddd+`      `+y:    .sddddddddddh   Shell: ash
ddddddddh+`   `//`   `.`     -sddddddddd   Resolution: 1920x1080
ddddddh+`   `/hddh/`   `:s-    -sddddddd   Terminal: /dev/pts/3
ddddh+`   `/+/dddddh/`   `+s-    -sddddd   CPU: Intel i7-7700HQ (2) @ 3.800GHz
ddd+`   `/o` :dddddddh/`   `oy-    .yddd   Memory: 20MiB / 256MiB
hdddyo+ohddyosdddddddddho+oydddy++ohdddh
.hddddddddddddddddddddddddddddddddddddh.
 `yddddddddddddddddddddddddddddddddddy`
caddy:~# caddy
Caddy run with root user but as is a isolated LXC container this should not be a problem.
#!/sbin/openrc-run
supervisor=supervise-daemon
name="Caddy web server"
description="Fast, multi-platform web server with automatic HTTPS"
description_checkconfig="Check configuration"
description_reload="Reload configuration without downtime"
: ${caddy_opts:="--config /etc/caddy/Caddyfile --adapter caddyfile"}
command=/usr/sbin/caddy
command_args="run $caddy_opts"
command_user=caddy:caddy
extra_commands="checkconfig"
extra_started_commands="reload"
capabilities="^cap_net_bind_service"
depend() {
        need net localmount
        after firewall
checkconfig() {
        ebegin "Checking configuration for $name"
        su ${command_user%:*} -s /bin/sh -c "$command validate $caddy_opts"
        eend $?
reload() {
        ebegin "Reloading $name"
        su ${command_user%:*} -s /bin/sh -c "$command reload $caddy_opts"
        eend $?
stop_pre() {
        if [ "$RC_CMD" = restart ]; then
                checkconfig || return $?
        fi
        events {
(cloudflare) {
        tls username@home.arpa {
                dns cloudflare <secret>
(vips_only) {
        @fuck_off_world {
                not remote_ip 10.1.1.0/24 186.222.222.222/32
        respond @fuck_off_world 403
adguard.home.arpa {
        import cloudflare
        import vips_only
        reverse_proxy http://adguard.home.arpa:80
caddy.home.arpa {
       import cloudflare
       import vips_only
       root * /var/www
       file_server browse
ldap.home.arpa {
        import cloudflare
        import vips_only
        respond "LDAP"
pve-01.home.arpa {
        import cloudflare
        import vips_only
        reverse_proxy https://pve-01.home.arpa:8006 {
                        tls_insecure_skip_verify
*.caddy.home.arpa {
        import cloudflare
        import vips_only
        @adguard host adguard.caddy.home.arpa
        handle @adguard {
        @pve-01 host pve-01.caddy.home.arpa
        handle @pve-01 {
        # Fallback for otherwise unhandled domains
                abort
At first I want to do two things:
  • copy certificate pve-01.home.arpa to host running Proxmox
  • copy certificate ldap.home.arpa to LXC container running OpenLDAP
Afterwards, whenever Caddy renews the certificates, the script must run and copy the new certificates.
Important:
I used the apk add caddy command to install Caddy using Alpine’s package manager and then I replaced the Caddy executable in /usr/sbin/caddy with the one I downloaded from the site* already with the “caddy-dns” plugins /cloudflare" and “mholt/caddy-events-exec” (indicated on the Global options (Caddyfile) — Caddy Documentation page).
*wget -q -O /usr/sbin/caddy "https://caddyserver.com/api/download?os=linux&arch=amd64&p=github.com%2Fcaddy-dns%2Fcloudflare&p=github.com%2Fmholt%2Fcaddy-events-exec"
So Caddy is running as the caddy user and not as root. Probably makes sense that it can’t run commands in /root since those are owned by root.
Move the commands to /etc/caddy or something instead.
You were right, it was problem with permissions.
I thought Caddy was running as root user.
I first moved the certificate_obtained.sh file to /etc/caddy/ and then chown caddy:caddy in /etc/caddy/.
It didn’t seem to work but that’s because for testing purposes I just wanted to create a log file with the received parameters.
It was necessary to change the owner of the /etc/caddy/ folder to caddy for the script to run and create the log file.
