Error with socket on 2.5?
1. Caddy version (caddy version): 2.5.0
2. How I run Caddy: systemctl
a. System environment: Ubuntu 20.04.4
systemctl reload caddy
# caddy.service
# for your installation.
Type=notify
RuntimeDirectory=caddy
        email (MY EMAIL GOES HERE)
        #    admin off
        admin unix///var/run/caddy/caddy.sock
(php74) {
(grav) {
        route {
                header Cache-Control max-age=3600
                header /assets/* Cache-Control max-age=16200000
                header /system/* Cache-Control max-age=16200000
                header /user/* Cache-Control max-age=16200000
        # Begin - Security
        # deny all direct access for these folders
        rewrite /(\.git|cache|bin|logs|backups|tests)/.* /403
        # deny running scripts inside core system folders
        rewrite /(system|vendor)/.*\.(txt|xml|md|html|yaml|yml|php|pl|py|cgi|twig|sh|bat)$ /403
        # deny running scripts inside user folder
        rewrite /user/.*\.(txt|md|yaml|yml|php|pl|py|cgi|twig|sh|bat)$ /403
        # deny access to specific files in the root folder
        rewrite /(LICENSE\.txt|composer\.lock|composer\.json|nginx\.conf|web\.config|htaccess\.txt|\.htaccess) /403
        respond /403 403
        ## End - Security
        # global rewrite should come last.
        try_files {path} {path}/ /index.php?_url={uri}&{query}
(secure) {
                # enable HSTS
                # clickjacking protection
                X-Frame-Options DENY
(wordpress) {
        # cache static content
        header /wp-content/cache/* Cache-Control max-age=14400
(logfile) {
                output file /srv/apps/{args.0}/logs/access.log
import /srv/config/caddy/enabled/*
May 05 17:01:51 alycia caddy[3466]: {"level":"info","ts":1651770111.6170058,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
May 05 17:01:51 alycia caddy[3466]: {"level":"warn","ts":1651770111.6285775,"msg":"Caddyfile input is not formatted; run the 'caddy fmt' command to fix inconsistencies","adapter":"caddyfile>
May 05 17:01:51 alycia caddy[3466]: {"level":"info","ts":1651770111.6288965,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
May 05 17:01:51 alycia caddy[3466]: {"level":"warn","ts":1651770111.6351035,"msg":"Caddyfile input is not formatted; run the 'caddy fmt' command to fix inconsistencies","adapter":"caddyfile>
May 05 17:01:51 alycia caddy[3466]: reload: sending configuration to instance: performing request: Post "//%20/unixsocket/load": unsupported protocol scheme ""
May 05 17:01:51 alycia systemd[1]: caddy.service: Control process exited, code=exited, status=1/FAILURE
-- Subject: Unit process exited
-- Defined-By: systemd
-- Support: http://www.ubuntu.com/support
-- An ExecReload= process belonging to unit caddy.service has exited.
-- The process' exit code is 'exited' and its exit status is 1.
May 05 17:01:51 alycia systemd[1]: Reload failed for Caddy.
-- Subject: A reload job for unit caddy.service has finished
-- A reload job for unit caddy.service has finished.
-- The job identifier is 3722 and the job result is failed.
A few weeks ago, I tried to configure Caddy to bind admin API to a socket (see Caddyfile above, I also added RuntimeDirectory=caddy to service file to create a permissionned directory at launch. At that time I had Caddy 2.4.6 and everything worked fine.
I recently updated to Caddy 2.5.0, and trying to reload config through systemctl doesn’t work anymore as you can see above from journalctl -xe output
Note that my Caddyfile (and imported caddyfiles from /srv) should all be formatted correctly as they were ok before the update and didn’t change from the time I set up socket and now.
I looks like Caddy is not able to handle sockets in newest version ? Any clue on that ?
Thanks
Will you be able to give this a shot: Should `enforce_origin` and `origins` work over the unix socket? - #2 by IndeedNotJames
I had no idea people were even using this feature :man_facepalming:
You can’t use regexp in inline matchers, because the inline matcher uses the simple path matcher.
If you need regexp, then use a named matcher with path_regexp:
You also don’t need to rewrite then respond. Just directly respond according to the matcher.
Don’t use systemctl status caddy to read your logs, they get truncated. Notice the > at the end of lines. Instead, use the command mentioned here to read your logs:
For the unix socket issue, unfortunately a bug was introduced in v2.5.0, it’s fixed here:
I guess for now, stick with v2.4.6, or build from the master branch. Sorry! It’ll land in v2.5.1.
Thank you all. I searched a bit before posting but couldn’t find anything that this bug was reported… Should have searched deeper!
As this is mainly for tests purpose (I actually host a few personal websites but that are not critical at all), I will try maybe to build the latest version with xcaddy, that will give me a chance to explore that part.
These are directives that were provided with Grav CMS I took and pasted without giving them a shot (but still must admit I didn’t know about pat/path_regexp matchers…). I understand about the matcher, I should define it first then use it in rewrite/respond ou whatever… But still, it works like this actually… But I don’t understand about using only respond. From what I understand, rewrite is used first to “redirect” to the error page, then respond sends the error code? respond can only show a text (body) and not a particular page?
2.5.1 is out now and let me/us know if you still face the issue
:thinking:
Well I guess they didn’t test them, because it definitely won’t work as-is.
Yep, that’s right. You define a named matcher (i.e. something starting with @ followed by the name) which has a path_regexp matcher inside of it, then you apply that named matcher to a directive.
Yeah the config will load, but it won’t work, and they will never match anything. The path matcher is essentially comparing the string as-is, it doesn’t evaluate the regular expressions.
Now that I think of it, it’s possible Grav was showing Caddy v1 config, not Caddy v2. Rewrites and matchers are done differently now, in Caddy v2.
It’s not a redirect, it’s a rewrite. Those are different concepts. A redirect is a special kind of HTTP response which has a Location header, which tells the client to make a new request to the URL in the Location header.
A rewrite is internal to the server; the request’s URI (path + query) is modified before other handlers use it.
The config you had was doing a rewrite to /403 as a “special path” and then re-matching on /403 later to write a response.
The rewrite isn’t necessary, you can skip that intermediary step completely and just directly write the 403 response.
That’s right. If you want to show an error page, I recommend you use the error directive to trigger an error, then use handle_errors to handle particular error codes and use file_server to serve the error page. There’s an example in the docs:
