1. Output of
go version: 1.16.5
caddy version: 2.4.6
route53 version: 1.3.0
a. System environment: Windows 10
caddy.exe run
FileName: my.routing.com
(route) {
dns route53 {
region ...
access_key_id ...
secret_access_key ...
my.routing.com {
reverse_proxy staging.routing.com
import route
import my.routing.com
e. main.go file
package main
import (
caddycmd "github.com/caddyserver/caddy/v2/cmd"
// plug in Caddy modules here
_ "github.com/caddyserver/caddy/v2/modules/standard"
_ "github.com/caddy-dns/route53"
func main() {
caddycmd.Main()
I trying to use caddy and route53 to automatically renew the certificate through caddy
However, whenever I set and run route53 tls, the following error appears
And when I access the site, I get a warning that it’s not safe
2022/11/23 08:11:39.862 e[34mINFOe[0m tls.issuance.acme waiting on internal rate limiter {"identifiers": ["my.routing.com"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": ""}
2022/11/23 08:11:39.862 e[34mINFOe[0m tls.issuance.acme done waiting on internal rate limiter {"identifiers": ["my.routing.com"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": ""}
2022/11/23 08:11:40.978 e[34mINFOe[0m tls.issuance.acme.acme_client trying to solve challenge {"identifier": "my.routing.com", "challenge_type": "dns-01", "ca": "https://acme-v02.api.letsencrypt.org/directory"}
2022/11/23 08:11:43.056 e[31mERRORe[0m tls.issuance.acme.acme_client cleaning up solver {"identifier": "my.routing.com", "challenge_type": "dns-01", "error": "no memory of presenting a DNS record for my.routing.com (probably OK if presenting failed)"}
2022/11/23 08:11:43.262 e[31mERRORe[0m tls.obtain could not get certificate from issuer {"identifier": "my.routing.com", "issuer": "acme-v02.api.letsencrypt.org-directory", "error": "[my.routing.com] solving challenges: presenting for challenge: adding temporary record for zone routing.com.: Error unquoting TXT/SPF record: invalid syntax (order=https://acme-v02.api.letsencrypt.org/acme/order/732212697/146722220587) (ca=https://acme-v02.api.letsencrypt.org/directory)"}
2022/11/23 08:11:43.264 e[33mWARNe[0m tls.issuance.zerossl missing email address for ZeroSSL; it is strongly recommended to set one for next time
2022/11/23 08:11:45.373 e[34mINFOe[0m tls.issuance.zerossl generated EAB credentials {"key_id": "blabla"}
I’ve been searching for information about this for days, but I’ve failed to solve the problem
I’m not sure which one was a meaningful attempt
I wrote a comment here, but Josh said it would be better to create a new post, so I’m creating a new one
