Hi there! First off want to thank the devs for creating such a great product! I’ve been using Caddy reverse proxy with Crowdsec and Authelia to host various sites and it’s been working perfectly! I’m just having trouble with the Immich app working with Authelia with Caddy as the reverse-proxy
I’m using Caddy reverse proxy to host Immich with Authelia for authentication. It works perfectly on a web browser. However, using the app throws errors in the Caddy logs.
{"level":"error","ts":1709057882.656811,"logger":"http.log.access.immich","msg":"handled request","request":{"remote_ip":"108.162.241.78","remote_port":"64374","client_ip":"38.85.165.230","proto":"HTTP/2.0","method":"GET","host":"immich.mason.dad","uri":"/api","headers":{"Cf-Ipcountry":["CA"],"X-Forwarded-For":["38.85.165.230"],"User-Agent":["Dart/3.2 (dart:io)"],"Cf-Connecting-Ip":["38.85.165.230"],"Cdn-Loop":["cloudflare"],"Accept-Encoding":["gzip"],"Cf-Ray":["85c26d960a3a54a9-YYZ"],"X-Forwarded-Proto":["https"],"Cf-Visitor":["{\"scheme\":\"https\"}"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"immich.mason.dad"}},"bytes_read":0,"user_id":"","duration":0.003330541,"size":115,"status":401,"resp_headers":{"X-Frame-Options":["SAMEORIGIN"],"Location":["https://auth.mason.dad/?rd=https%3A%2F%2Fimmich.mason.dad%2Fapi&rm=GET"],"Date":["Tue, 27 Feb 2024 18:18:02 GMT"],"Content-Type":["text/html; charset=utf-8"],"Permissions-Policy":["interest-cohort=()"],"X-Content-Type-Options":["nosniff"],"Alt-Svc":["h3=\":443\"; ma=2592000"],"Set-Cookie":[],"Content-Length":["115"],"Referrer-Policy":["strict-origin-when-cross-origin"],"X-Xss-Protection":["1; mode=block"],"Server":["Caddy"]}}
{"level":"error","ts":1709057882.8636556,"logger":"http.log.access.immich","msg":"handled request","request":{"remote_ip":"108.162.241.117","remote_port":"42772","client_ip":"38.85.165.230","proto":"HTTP/2.0","method":"GET","host":"immich.mason.dad","uri":"/api/.well-known/immich","headers":{"Cdn-Loop":["cloudflare"],"Accept-Encoding":["gzip"],"Cf-Ray":["85c26d9749df5437-YYZ"],"X-Forwarded-Proto":["https"],"User-Agent":["Dart/3.2 (dart:io)"],"Accept":["application/json"],"Cf-Ipcountry":["CA"],"X-Forwarded-For":["38.85.165.230"],"Cf-Visitor":["{\"scheme\":\"https\"}"],"Cf-Connecting-Ip":["38.85.165.230"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"immich.mason.dad"}},"bytes_read":0,"user_id":"","duration":0.000533741,"size":138,"status":401,"resp_headers":{"Server":["Caddy"],"Alt-Svc":["h3=\":443\"; ma=2592000"],"X-Content-Type-Options":["nosniff"],"X-Frame-Options":["SAMEORIGIN"],"X-Xss-Protection":["1; mode=block"],"Set-Cookie":[],"Permissions-Policy":["interest-cohort=()"],"Referrer-Policy":["strict-origin-when-cross-origin"],"Location":["https://auth.mason.dad/?rd=https%3A%2F%2Fimmich.mason.dad%2Fapi%2F.well-known%2Fimmich&rm=GET"],"Date":["Tue, 27 Feb 2024 18:18:02 GMT"],"Content-Type":["text/html; charset=utf-8"],"Content-Length":["138"]}}
{"level":"error","ts":1709057883.0426967,"logger":"http.log.access.immich","msg":"handled request","request":{"remote_ip":"172.69.214.34","remote_port":"9716","client_ip":"38.85.165.230","proto":"HTTP/2.0","method":"GET","host":"immich.mason.dad","uri":"/api/server-info/version","headers":{"Cf-Ipcountry":["CA"],"X-Forwarded-For":["38.85.165.230"],"Cf-Ray":["85c26d987b7636db-YYZ"],"Cf-Connecting-Ip":["38.85.165.230"],"User-Agent":["Dart/3.2 (dart:io)"],"Cdn-Loop":["cloudflare"],"Accept-Encoding":["gzip"],"X-Forwarded-Proto":["https"],"Cf-Visitor":["{\"scheme\":\"https\"}"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"immich.mason.dad"}},"bytes_read":0,"user_id":"","duration":0.001520894,"size":139,"status":401,"resp_headers":{"Referrer-Policy":["strict-origin-when-cross-origin"],"Location":["https://auth.mason.dad/?rd=https%3A%2F%2Fimmich.mason.dad%2Fapi%2Fserver-info%2Fversion&rm=GET"],"Content-Type":["text/html; charset=utf-8"],"Content-Length":["139"],"Alt-Svc":["h3=\":443\"; ma=2592000"],"X-Frame-Options":["SAMEORIGIN"],"X-Content-Type-Options":["nosniff"],"Permissions-Policy":["interest-cohort=()"],"X-Xss-Protection":["1; mode=block"],"Set-Cookie":[],"Date":["Tue, 27 Feb 2024 18:18:02 GMT"],"Server":["Caddy"]}}
{"level":"error","ts":1709057883.1072989,"logger":"http.log.access.immich","msg":"handled request","request":{"remote_ip":"172.69.214.34","remote_port":"9716","client_ip":"38.85.165.230","proto":"HTTP/2.0","method":"GET","host":"immich.mason.dad","uri":"/api/server-info/features","headers":{"Cf-Ray":["85c26d994ca736db-YYZ"],"Cf-Visitor":["{\"scheme\":\"https\"}"],"User-Agent":["Dart/3.2 (dart:io)"],"Cdn-Loop":["cloudflare"],"Accept-Encoding":["gzip"],"X-Forwarded-Proto":["https"],"Cf-Connecting-Ip":["38.85.165.230"],"Cf-Ipcountry":["CA"],"X-Forwarded-For":["38.85.165.230"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"immich.mason.dad"}},"bytes_read":0,"user_id":"","duration":0.001529564,"size":140,"status":401,"resp_headers":{"Server":["Caddy"],"Date":["Tue, 27 Feb 2024 18:18:03 GMT"],"X-Content-Type-Options":["nosniff"],"X-Frame-Options":["SAMEORIGIN"],"X-Xss-Protection":["1; mode=block"],"Set-Cookie":[],"Permissions-Policy":["interest-cohort=()"],"Alt-Svc":["h3=\":443\"; ma=2592000"],"Content-Type":["text/html; charset=utf-8"],"Content-Length":["140"],"Referrer-Policy":["strict-origin-when-cross-origin"],"Location":["https://auth.mason.dad/?rd=https%3A%2F%2Fimmich.mason.dad%2Fapi%2Fserver-info%2Ffeatures&rm=GET"]}}
{"level":"error","ts":1709057883.176247,"logger":"http.log.access.immich","msg":"handled request","request":{"remote_ip":"172.69.214.34","remote_port":"9716","client_ip":"38.85.165.230","proto":"HTTP/2.0","method":"GET","host":"immich.mason.dad","uri":"/api/server-info/config","headers":{"Cdn-Loop":["cloudflare"],"Cf-Ipcountry":["CA"],"X-Forwarded-Proto":["https"],"Cf-Connecting-Ip":["38.85.165.230"],"Accept-Encoding":["gzip"],"X-Forwarded-For":["38.85.165.230"],"Cf-Ray":["85c26d99ad5b36db-YYZ"],"Cf-Visitor":["{\"scheme\":\"https\"}"],"User-Agent":["Dart/3.2 (dart:io)"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"immich.mason.dad"}},"bytes_read":0,"user_id":"","duration":0.001400052,"size":138,"status":401,"resp_headers":{"Permissions-Policy":["interest-cohort=()"],"X-Frame-Options":["SAMEORIGIN"],"Location":["https://auth.mason.dad/?rd=https%3A%2F%2Fimmich.mason.dad%2Fapi%2Fserver-info%2Fconfig&rm=GET"],"Set-Cookie":[],"Content-Type":["text/html; charset=utf-8"],"Server":["Caddy"],"Alt-Svc":["h3=\":443\"; ma=2592000"],"Content-Length":["138"],"Referrer-Policy":["strict-origin-when-cross-origin"],"X-Xss-Protection":["1; mode=block"],"X-Content-Type-Options":["nosniff"],"Date":["Tue, 27 Feb 2024 18:18:03 GMT"]}}
{"level":"error","ts":1709057905.3008428,"logger":"http.log.access.immich","msg":"handled request","request":{"remote_ip":"172.69.214.242","remote_port":"14996","client_ip":"38.85.165.230","proto":"HTTP/2.0","method":"GET","host":"immich.mason.dad","uri":"/api","headers":{"Cdn-Loop":["cloudflare"],"X-Forwarded-For":["38.85.165.230"],"X-Forwarded-Proto":["https"],"Cf-Connecting-Ip":["38.85.165.230"],"Cf-Ipcountry":["CA"],"Accept-Encoding":["gzip"],"Cf-Ray":["85c26e239da536d8-YYZ"],"Cf-Visitor":["{\"scheme\":\"https\"}"],"User-Agent":["Dart/3.2 (dart:io)"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"immich.mason.dad"}},"bytes_read":0,"user_id":"","duration":0.001637642,"size":115,"status":401,"resp_headers":{"X-Content-Type-Options":["nosniff"],"Referrer-Policy":["strict-origin-when-cross-origin"],"Server":["Caddy"],"Permissions-Policy":["interest-cohort=()"],"X-Xss-Protection":["1; mode=block"],"Date":["Tue, 27 Feb 2024 18:18:25 GMT"],"Content-Type":["text/html; charset=utf-8"],"Alt-Svc":["h3=\":443\"; ma=2592000"],"Location":["https://auth.mason.dad/?rd=https%3A%2F%2Fimmich.mason.dad%2Fapi&rm=GET"],"Set-Cookie":[],"Content-Length":["115"],"X-Frame-Options":["SAMEORIGIN"]}}
{"level":"error","ts":1709057905.4867058,"logger":"http.log.access.immich","msg":"handled request","request":{"remote_ip":"172.69.214.68","remote_port":"11466","client_ip":"38.85.165.230","proto":"HTTP/2.0","method":"GET","host":"immich.mason.dad","uri":"/api/.well-known/immich","headers":{"X-Forwarded-Proto":["https"],"Cf-Visitor":["{\"scheme\":\"https\"}"],"User-Agent":["Dart/3.2 (dart:io)"],"Accept":["application/json"],"Cf-Ipcountry":["CA"],"Accept-Encoding":["gzip"],"X-Forwarded-For":["38.85.165.230"],"Cf-Ray":["85c26e24d8bc3a04-YYZ"],"Cf-Connecting-Ip":["38.85.165.230"],"Cdn-Loop":["cloudflare"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"immich.mason.dad"}},"bytes_read":0,"user_id":"","duration":0.00161921,"size":138,"status":401,"resp_headers":{"X-Xss-Protection":["1; mode=block"],"Content-Length":["138"],"Referrer-Policy":["strict-origin-when-cross-origin"],"Permissions-Policy":["interest-cohort=()"],"Location":["https://auth.mason.dad/?rd=https%3A%2F%2Fimmich.mason.dad%2Fapi%2F.well-known%2Fimmich&rm=GET"],"Alt-Svc":["h3=\":443\"; ma=2592000"],"X-Content-Type-Options":["nosniff"],"X-Frame-Options":["SAMEORIGIN"],"Set-Cookie":[],"Date":["Tue, 27 Feb 2024 18:18:25 GMT"],"Content-Type":["text/html; charset=utf-8"],"Server":["Caddy"]}}
{"level":"error","ts":1709057905.6700306,"logger":"http.log.access.immich","msg":"handled request","request":{"remote_ip":"172.69.214.105","remote_port":"47890","client_ip":"38.85.165.230","proto":"HTTP/2.0","method":"POST","host":"immich.mason.dad","uri":"/api/oauth/authorize","headers":{"Cdn-Loop":["cloudflare"],"Cf-Ipcountry":["CA"],"Content-Length":["30"],"X-Forwarded-Proto":["https"],"User-Agent":["Dart/3.2 (dart:io)"],"Cf-Connecting-Ip":["38.85.165.230"],"Accept-Encoding":["gzip"],"X-Forwarded-For":["38.85.165.230"],"Cf-Ray":["85c26e25fc3936ff-YYZ"],"Cf-Visitor":["{\"scheme\":\"https\"}"],"Content-Type":["application/json; charset=utf-8"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"immich.mason.dad"}},"bytes_read":0,"user_id":"","duration":0.00153216,"size":136,"status":401,"resp_headers":{"Set-Cookie":[],"Server":["Caddy"],"Content-Length":["136"],"Referrer-Policy":["strict-origin-when-cross-origin"],"Permissions-Policy":["interest-cohort=()"],"Location":["https://auth.mason.dad/?rd=https%3A%2F%2Fimmich.mason.dad%2Fapi%2Foauth%2Fauthorize&rm=POST"],"X-Content-Type-Options":["nosniff"],"X-Frame-Options":["SAMEORIGIN"],"Alt-Svc":["h3=\":443\"; ma=2592000"],"Date":["Tue, 27 Feb 2024 18:18:25 GMT"],"Content-Type":["text/html; charset=utf-8"],"X-Xss-Protection":["1; mode=block"]}}
Installed using Docker with multiple Caddy modules
xcaddy build
–with GitHub - WeidiDeng/caddy-cloudflare-ip
–with GitHub - caddy-dns/cloudflare: Caddy module: dns.providers.cloudflare
–with GitHub - mholt/caddy-dynamicdns: Caddy app that keeps your DNS records (A/AAAA) pointed at itself.
–with GitHub - hslatman/caddy-crowdsec-bouncer: A Caddy module that blocks malicious traffic based on decisions made by CrowdSec.
Ubuntu 22.04 with Docker
N/A
Caddy compose file
version: '3.8'
image: caddy:2
restart: always
- 60443:443
- 60443:443/udp
- 2019:2019
- ./caddy:/usr/bin/caddy:ro
- caddy-data:/data
- caddy-config:/config
- caddy-logs:/var/log/caddy
- CLOUDFLARE_API_TOKEN=MY_CLOUDFLARE_TOKEN
default:
ipv4_address: 172.50.0.4
security_opt:
- no-new-privileges=true
cap_add:
- NET_ADMIN
caddy-data:
caddy-config:
caddy-logs:
default:
ipam:
driver: default
Authelia Compose file
version: '3'
authelia:
image: authelia/authelia
container_name: authelia
- ./config:/config
- authelia-logs:/var/log/authelia
- /myDrive/docker-volumes/authelia/auth-data:/data
caddy-network:
ipv4_address: 172.50.0.8
restart: always
- TZ=America/Toronto
caddy-network:
external: true
authelia-logs:
email {$EMAIL}
acme_dns cloudflare {$CLOUDFLARE_API_TOKEN}
admin :2019
include http.log.access.immich http.log.access.auth
level DEBUG
roll_size 50MB
roll_keep 50
order crowdsec first
crowdsec {
api_url http://172.50.0.6:8080
api_key {$CROWDSEC_API_KEY}
dynamic_dns {
provider cloudflare {$CLOUDFLARE_API_TOKEN}
domains {
mason.dad @ immich authelia
ip_source simple_http https://api64.ipify.org
ip_source simple_http https://ifconfig.me
ip_source simple_http https://icanhazip.com
check_interval 30m
versions ipv4
servers {
trusted_proxies cloudflare {
interval 6h
timeout 30s
immich.mason.dad {
forward_auth authelia:9091 {
uri /api/verify?rd=https://auth.mason.dad/
copy_headers Remote-User Remote-Groups Remote-Name Remote-Email
crowdsec
reverse_proxy 10.10.10.10:2283
log immich
auth.mason.dad {
crowdsec
reverse_proxy authelia:9091
log auth
