Error when using handle_errors inside route
2.4.3
Windows 10 Build 19043
caddy run -watch
N/A
	auto_https off
www.erindachtler.me {
	redir https://erindachtler.me{uri}
erindachtler.me, :80 { # :80is for testing
	encode gzip zstd
	handle_path /pomodoro/* {
		root content/elm-pomodoro/dist/
	route /romans/* {
		root content/romans-pizza/public/
		uri strip_prefix /romans
		try_files {path}.html
		file_server {
			hide 404.html
		handle_errors {
			@404 expression `{http.error.status_code} == 404`
			try_files @404 /404.html
	route {
		root content/resume
I’m trying to put some static projects into directories on my server.
In the case of one of these (romans) I want to display a 404 page on no matching files.
It seems to be giving some kind of error about handle_errors not being allowed inside a route block.
I would think handle_errors would count as a “handler directive” since you are presumably going to handle the error inside it.
Is this a bug, or am I not using the directives correctly?
2021/07/25 15:45:53.081 INFO    using adjacent Caddyfile
run: adapting config using caddyfile: parsing caddyfile tokens for 'route': Caddyfile:36 - Error during parsing: handle_errors directive returned something other than an HTTP route or subroute: &caddyhttp.Subroute{Routes:caddyhttp.RouteList{caddyhttp.Route{Group:"", MatcherSetsRaw:caddyhttp.RawMatcherSets{caddy.ModuleMap{"file":json.RawMessage{0x7b, 0x22, 0x74, 0x72, 0x79, 0x5f, 0x66, 0x69, 0x6c, 0x65, 0x73, 0x22, 0x3a, 0x5b, 0x22, 0x40, 0x34, 0x30, 0x34, 0x22, 0x2c, 0x22, 0x2f, 0x34, 0x30, 0x34, 0x2e, 0x68, 0x74, 0x6d, 0x6c, 0x22, 0x5d, 0x7d}}}, HandlersRaw:[]json.RawMessage{json.RawMessage{0x7b, 0x22, 0x68, 0x61, 0x6e, 0x64, 0x6c, 0x65, 0x72, 0x22, 0x3a, 0x22, 0x72, 0x65, 0x77, 0x72, 0x69, 0x74, 0x65, 0x22, 0x2c, 0x22, 0x75, 0x72, 0x69, 0x22, 0x3a, 0x22, 0x7b, 0x68, 0x74, 0x74, 0x70, 0x2e, 0x6d, 0x61, 0x74, 0x63, 0x68, 0x65, 0x72, 0x73, 0x2e, 0x66, 0x69, 0x6c, 0x65, 0x2e, 0x72, 0x65, 0x6c, 0x61, 0x74, 0x69, 0x76, 0x65, 0x7d, 0x22, 0x7d}}, Terminal:false, MatcherSets:caddyhttp.MatcherSets(nil), Handlers:[]caddyhttp.MiddlewareHandler(nil), middleware:[]caddyhttp.Middleware(nil)}, caddyhttp.Route{Group:"", MatcherSetsRaw:caddyhttp.RawMatcherSets(nil), HandlersRaw:[]json.RawMessage{json.RawMessage{0x7b, 0x22, 0x68, 0x61, 0x6e, 0x64, 0x6c, 0x65, 0x72, 0x22, 0x3a, 0x22, 0x66, 0x69, 0x6c, 0x65, 0x5f, 0x73, 0x65, 0x72, 0x76, 0x65, 0x72, 0x22, 0x2c, 0x22, 0x68, 0x69, 0x64, 0x65, 0x22, 0x3a, 0x5b, 0x22, 0x2e, 0x5c, 0x5c, 0x43, 0x61, 0x64, 0x64, 0x79, 0x66, 0x69, 0x6c, 0x65, 0x22, 0x5d, 0x7d}}, Terminal:false, MatcherSets:caddyhttp.MatcherSets(nil), Handlers:[]caddyhttp.MiddlewareHandler(nil), middleware:[]caddyhttp.Middleware(nil)}}, Errors:(*caddyhttp.HTTPErrorConfig)(nil)} (only handler directives can be used in routes)
Tried using handle_path instead of route but it said that’s not allowed:
parsing caddyfile tokens for 'handle_path': directive 'handle_errors' is not ordered, so it cannot be used here
The handle_errors directive is a bit special – it must be used as the top-level, because it’s a site-wide error handler, not per route. You may use a matcher/routes within your handle_errors block though.
The way handle_errors works is as an alternate request handling chain, so if any error is encountered in that site (errors emitted by Caddy), it will then pass it through the error handler chain if configured. It’s not really conditionally registered; it’s either defined or it’s not.
You can use handle_path instead of route + uri strip_prefix here to save a line, since handle_path has built-in prefix stripping behaviour.
Thanks! I was able to fix it by moving the handle_errors block to the root of the site block and duplicating the path matching inside it.
handle_errors {
	@romans404 {
		path /romans/*
	route @romans404 {
