I’m trying to use the tls ciphers directive to specify a list of allowed cipher suites. A customer wants to exclude CBC ciphers.
We realize it’s preferable not to change the defaults and we’ve advised our customer accordingly. However, we want to make sure we can disable the CBC ciphers if they insist.
root-web.1.ztu1dhvb9oba@ubuntu-s-8vcpu-16gb-intel-nyc3-01 | {"level":"info","ts":1680806830.4784403,"msg":"using provided configuration","config_file":"/tmpapp/CaddyfileForContainer","config_adapter":""}
root-web.1.ztu1dhvb9oba@ubuntu-s-8vcpu-16gb-intel-nyc3-01 | Error: adapting config using caddyfile: /tmpapp/CaddyfileForContainer:9: unrecognized directive: ciphers
Built off commit f8b59e77f83c05da87bd5e3780fb7522b863d462 on master branch
Built docker image containing executable mentioned above
Alpine docker image
./caddy run --config /tmpapp/CaddyfileForContainer
FROM alpine:3.16.4
ENV CADDYPATH=/tmpapp
ENV XDG_DATA_HOME=/tmpapp
ENV XDG_CONFIG_HOME=/tmpapp
WORKDIR /app
COPY . .
RUN set -eux && \
apk add --no-cache libcap nss-tools && \
adduser -u 10654 -g amag -s /bin/false --disabled-password amag && chown amag:amag -R /app && \
setcap CAP_NET_BIND_SERVICE=+eip /app/caddy
USER amag
EXPOSE 8080 8443
HEALTHCHECK --interval=5s --timeout=5s --start-period=5s --retries=3 CMD \
wget -S -q --spider http://localhost:8080/health-check || wget -S -q --spider http://localhost:8080/health-check 2>&1 | grep "308 Permanent Redirect" || exit 1
ENTRYPOINT ["/app/run.sh"]
# Header
https_port 8443
http_port 8080
# CADDY Body
tls /run/secrets/rootweb_idm_pem /run/secrets/rootweb_idm_key {
ciphers TLS_RSA_WITH_AES_128_GCM_SHA256 TLS_RSA_WITH_AES_256_GCM_SHA384 TLS_AES_128_GCM_SHA256 TLS_AES_256_GCM_SHA384 TLS_CHACHA20_POLY1305_SHA256 TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384 TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256 TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256
# START InBody Customization
# END InBody Customization
log
# Disallow the site to be rendered within a frame on different domain (clickjacking protection)
+X-Frame-Options "SAMEORIGIN"
-Server
-x-powered-by
+Access-Control-Allow-Headers Range
+Access-Control-Expose-Headers "Accept-Ranges, Content-Encoding, Content-Length, Content-Range"
#Implement Security Headers
Strict-Transport-Security "max-age=31536000; includeSubDomains"
Content-Security-Policy "default-src data: https:; font-src data: https:; frame-src 'self' https: mailto: tel:; img-src data: https: http://localhost:1337 http://localhost:1338; script-src https: 'unsafe-inline' 'unsafe-eval'; style-src https: 'unsafe-inline'; connect-src https: ws://localhost:* wss: 'self' http://localhost:1337/* *.firebaseio.com"
Permissions-Policy "accelerometer=(), camera=(self), geolocation=(), gyroscope=(), magnetometer=(), microphone=(), payment=(), usb=(), interest-cohort=()"
# Enabling CORS for CDN Only
# The default Same-Origin Policy is enough for the web and apis
# Set mime type for specific file as content sniffing is now disabled
# and browser needs to still behave as expected:
# - opening the file inside a tab as text or image for example,
# - downloading the file instead of opening it as text...
@exe {
path *.exe
header @exe Content-Type application/octet-stream
@ttf {
path *.ttf
header @ttf Content-Type font/ttf
@woff {
path *.woff
header @woff Content-Type font/woff
@woff2 {
path *.woff2
header @woff2 Content-Type font/woff2
@mem {
path *.mem
header @mem Content-Type application/octet-stream
@ico {
path *.ico
header @ico Content-Type image/x-icon
@pk {
path *.pkpass
header @pk Content-Type application/vnd.apple.pkpass
header /cdn* {
+Access-Control-Allow-Origin "*"
#mime .xlsx application/vnd.openxmlformats-officedocument.spreadsheetml.sheet
@xlsx {
path *.xlsx
header @xlsx Content-Type application/vnd.openxmlformats-officedocument.spreadsheetml.sheet
@txt {
path *.txt
header @txt Content-Disposition attachment
@csv {
path *.csv
header @csv Content-Disposition attachment
respond /health-check 200
# Rewrite rules to eliminate case issues. Proxy
# routes are case sensitive
redir /G4S.Portal.Web/ /AMAG.Auth
# rewrite /G4S.Portal.Web /AMAG.Portal - Above line used instead to bring new prospect signups to login screen vs Portal.
rewrite /Amag.Auth /AMAG.Auth
rewrite / /AMAG.Auth
rewrite /OneFacilityLoginWeb/Login/Login.mvc /AMAG.Auth
@amag-auth {
path /G4S.Portal.Web
path /Amag.Auth
path /AMAG.Auth
path /
path /OneFacilityLoginWeb/Login/Login.mvc
# CDN Image Resizer
@cdn_resize {
path /cdn/photos*
not query ""
not query random=*
rewrite @cdn_resize /display/resize/0x0{path}
reverse_proxy /display/* http://picfit:7319
# DOCUMENTATION
redir /documentation /documentation/
route /documentation/* {
uri strip_prefix /documentation
root * /app/cdn/documentation
# S3 CDN
# Self hosted kestrel (.net core)
reverse_proxy /AMAG.Auth* auth-web:7325
reverse_proxy /AMAG.Portal* portal-web:7326
reverse_proxy /amag.sso* sso-web:7328
## Below two proxies needed since JS points to old locations
#reverse_proxy /G4S.Portal.Web/public/ localhost:7326/AMAG.Portal/public/ {
# without /G4S.Portal.Web/public/
reverse_proxy /G4S.Portal.Web/public* portal-web:7326
reverse_proxy /Amag.Login.Web/Login/Login* auth-web:7325
# Self hosted React Apps (caddy)
route /G4S.Registration.Web/* {
uri strip_prefix /G4S.Registration.Web
reverse_proxy registration-web:7320
@cac-web {
path /Amag.CAC.Web/*
path /AMAG.CAC.Web/*
route @cac-web {
uri strip_prefix /AMAG.CAC.Web
uri strip_prefix /Amag.CAC.Web
reverse_proxy cac-web:7323
route /G4S.IdentityManagement.Web/* {
uri strip_prefix /G4S.IdentityManagement.Web
reverse_proxy idm-web:7324
route /G4S.VMS.Web/* {
uri strip_prefix /G4S.VMS.Web
reverse_proxy vms-web:7327
# Self hosted ReST APIs (servicestack)
route /G4S.Registration.WebApi/api/* {
uri strip_prefix /G4S.Registration.WebApi/api
reverse_proxy registration-api:7120
route /AMAG.Symmetry.WebApi/api/* {
uri strip_prefix /AMAG.Symmetry.WebApi/api
reverse_proxy symmetry-api:7121
route /G4S.Core.WebApi/api/* {
uri strip_prefix /G4S.Core.WebApi/api
reverse_proxy core-api:7122
@cac-api {
path /Amag.CAC.WebApi/*
path /AMAG.CAC.WebApi/*
route @cac-api {
uri strip_prefix /AMAG.CAC.WebApi/api
uri strip_prefix /Amag.CAC.WebApi/api
reverse_proxy cac-api:7123
route /G4S.IdentityManagement.WebApi/api/* {
uri strip_prefix /G4S.IdentityManagement.WebApi/api
reverse_proxy idm-api:7124
route /G4S.VMS.WebApi/api/* {
uri strip_prefix /G4S.VMS.WebApi/api
reverse_proxy vms-api:7127
route /AMAG.Public/api/* {
uri strip_prefix /AMAG.Public/api
reverse_proxy public-api:7130
handle_path /G4S.VMS.WebSocketHub {
rewrite * /websockethub?{query}
reverse_proxy vms-websocket:5100
redir / /AMAG.Portal
# IIS hosted applications
# NOTE: one entry can cover both web & webApi
