I want to serve a simple HTML page in response to an http request. I used the example provided in the docs
Jul 06 21:34:30 ==> Starting Caddy
Jul 06 21:34:30 2025/07/07 04:34:30.468 INFO using provided configuration {"config_file": "/etc/caddy/Caddyfile", "config_adapter": ""}
Jul 06 21:34:30 Error: adapting config using caddyfile: /etc/caddy/Caddyfile:6: unrecognized directive: <html>
Jul 06 21:34:30 Error: caddy process exited with error: exit status 1
apt-get install -y --no-install-recommends caddy
It’s a docker image based on Cloudron’s app base image. I believe it’s Ubuntu based.
/usr/local/bin/gosu cloudron:cloudron /app/code/bin/agate --content /app/data/public/ --certs /app/data/certs/ --addr 0.0.0.0:1965 --hostname ${CLOUDRON_APP_DOMAIN} --lang en-US
Not sure what that is in my case.
http:// {
# -- The purpose of Caddy here is to respond to Cloudron's health check on port 80
# -- and display an information message for HTTP browsers.
header Content-Type text/html
respond <<HTML
<html>
<head><title>Foo</title></head>
<body>Foo</body>
</html>
HTML 200
