Error: unknown command "caddy" for "caddy"
I’m getting an error:
Error: unknown command “caddy” for “caddy”
2. Installation:
I’m trying to run a docker-compose file with a couple of services. But I get the error above.
I want to redirect my https://localhost:8055 (directus) to a domain.
This is my caddy service in my docker compose file.
It doesn’t make sense to use caddy-docker-proxy if you’re going to override the command with caddy reverse-proxy. CDP requires that it uses the docker-proxy command for its functionality to work.
You should either use a Caddyfile (mounted via a volume), or use labels with CDP to generate a config. The reverse-proxy command is only meant for quick-and-dirty local development, not for a long-running server.
