Hi,
(and thanks for all that amazing stuff)
Caddy is (newly) setup in between legacy IIS/ARR reverse proxies and IIS application servers. Intent is to filter some requests as it becomes tricky to do so with regex and url_rewrite on IIS.
Communication scheme:
client --https–> IIS/ARR --http–> caddy --http–> IIS/App
Caddy is doing its job perfectly relaying requests and responses except in one case, with one heavy page wich is about 9MB and renders in a bit more of 20 seconds.
Bypassing Caddy, IIS/ARR is providing HTTP 200 response with 9MB in 22 seconds.
With Caddy, IIS/ARR is providing HTTP 502 response with default IIS error page for this error in ~20 seconds. Caddy is logging an HTTP 0 (see log below).
messages : “aborting with incomplete response” and “short write” are provided.
I digged into documentation for any timeout/limit available directive and tested various combinations without any success.
I have to redact hostname, application is not public.
"level": "error",
"ts": "2024-04-25T18:18:55.464Z",
"msg": "aborting with incomplete response",
"upstream": "{upstream2}",
"duration": 21.179585692,
"request": {
"remote_ip": "10.20.3.8",
"remote_port": "65277",
"client_ip": "10.20.3.8",
"proto": "HTTP/1.1",
"method": "GET",
"host": "redacted",
"uri": "/Default.aspx?pageId=1549&ArtId=1129",
"headers": {
"Accept-Language": [
"en-US,en;q=0.9,fr;q=0.8,fr-FR;q=0.7"
"1"
"X-Arr-Log-Id": [
"e5330f39-9f22-4566-a046-279b64edeb53"
"Accept-Encoding": [
"gzip, deflate, br, zstd"
"Sec-Fetch-Site": [
"none"
"X-Original-Url": [
"Priority": [
"u=0, i"
"User-Agent": [
"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/124.0.0.0 Safari/537.36 Edg/124.0.0.0"
"X-Forwarded-For": [
"10.20.3.8"
"X-Forwarded-Host": [
"redacted"
"Sec-Fetch-Dest": [
"document"
"Max-Forwards": [
"10"
"Sec-Ch-Ua-Mobile": [
"?0"
"Cache-Control": [
"max-age=0"
"Sec-Fetch-Mode": [
"navigate"
"Sec-Fetch-User": [
"?1"
"Sec-Ch-Ua-Platform": [
"\"Windows\""
"X-Forwarded-Proto": [
"http"
"Cookie": [],
"Sec-Ch-Ua": [
"\"Chromium\";v=\"124\", \"Microsoft Edge\";v=\"124\", \"Not-A.Brand\";v=\"99\""
"Accept": [
"text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"
"error": "short write"
caddy is ran as a service with systemctl
ubuntu 22.04
go 1.22.2
using xcaddy with coraza
(coraza is in readonly mode)
sudo service caddy start
upstream configuration is coming from a map directive.
Configuration is pretty long, shorten to reverse_proxy configuration for better readability.
reverse_proxy {
to {upstream1}
to {upstream2}
lb_policy cookie
@error status 403 404 500 502 503
handle_response @error {
# the below directive is important if we want to keep track of
# the respone headers
copy_response_headers
root * /reverseproxy/content/
rewrite * /{rp.status_code}.html
Thanks a lot for any clue, advice,
Stephane
