ERROR: Service 'caddy' failed to build: manifest for caddy/caddy:v1.0.4 not found
Hi All,
After deploying docker stack the service of monitoring_caddy is showing 0/1 that means container is restarting or excited below is logs of that container
How to solve below error
mohd@master-node:~/Music/Exception-Email-Notification/docker-elk$ tail -f /var/log/syslog | grep monitoring_caddy
May 18 18:37:06 master-node dockerd[24124]: time="2021-05-18T18:37:06.375762053+05:30" level=warning msg="failed to deactivate service binding for container monitoring_caddy.1.t58vtbroif3q2thqffwctcqmt" error="No such container: monitoring_caddy.1.t58vtbroif3q2thqffwctcqmt" module=node/agent node.id=kwpyr5ixo3xx6psp782zxtgre
May 18 18:37:11 master-node dockerd[24124]: time="2021-05-18T18:37:11.449848246+05:30" level=warning msg="failed to deactivate service binding for container monitoring_caddy.1.hy25gdcm77n5g8jyg3ezd1sb8" error="No such container: monitoring_caddy.1.hy25gdcm77n5g8jyg3ezd1sb8" module=node/agent node.id=kwpyr5ixo3xx6psp782zxtgre
May 18 18:37:23 master-node dockerd[24124]: time="2021-05-18T18:37:23.539386392+05:30" level=warning msg="failed to deactivate service binding for container monitoring_caddy.1.kra1h18errc8p9xfy9j10kx23" error="No such container: monitoring_caddy.1.kra1h18errc8p9xfy9j10kx23" module=node/agent node.id=kwpyr5ixo3xx6psp782zxtgre
May 18 18:37:39 master-node dockerd[24124]: time="2021-05-18T18:37:39.003306905+05:30" level=warning msg="failed to deactivate service binding for container monitoring_caddy.1.jb0v9d5y7y4on7bi13mkfgjiz" error="No such container: monitoring_caddy.1.jb0v9d5y7y4on7bi13mkfgjiz" module=node/agent node.id=kwpyr5ixo3xx6psp782zxtgre
May 18 18:37:47 master-node dockerd[24124]: time="2021-05-18T18:37:47.317473411+05:30" level=warning msg="failed to deactivate service binding for container monitoring_caddy.1.w3wlxsumjk0ez3ugdp33zye0l" error="No such container: monitoring_caddy.1.w3wlxsumjk0ez3ugdp33zye0l" module=node/agent node.id=kwpyr5ixo3xx6psp782zxtgre
May 18 18:37:53 master-node dockerd[24124]: time="2021-05-18T18:37:53.514228691+05:30" level=warning msg="failed to deactivate service binding for container monitoring_caddy.1.v61dxkk09exrfpc7bxjaf6md3" error="No such container: monitoring_caddy.1.v61dxkk09exrfpc7bxjaf6md3" module=node/agent node.id=kwpyr5ixo3xx6psp782zxtgre
^Z
Here is the
docker-compose.yml
version: "3.3"
  certs: {}
    build:
      context: .
      dockerfile: Dockerfile
      args:
        CADDY_VERSION: ${CADDY_VERSION:-0.10.9}
    image: openfaas/caddy:${CADDY_VERSION:-0.10.9}
      - 443:443
      - 9180:9180
      - certs:/.caddy
    healthcheck:
      test: ["CMD", "curl", "-f", "http://localhost:80"]
      interval: 5s
      timeout: 1s
      retries: 3
Here is the
Dockerfile
FROM caddy/caddy:v1.0.4
COPY Caddyfile /etc/config/Caddyfile
Here is the Caddyfile
    gzip
    browse
    prometheus 0.0.0.0:9180
    log stdout
    errors stderr
    ext .md
    markdown
even i have index file also
all files are in caddy-builder folder
When i try to create docker image i got error in terminal
CADDY_VERSION=0.10.9 docker-compose build caddy
Building caddy
Step 1/2 : FROM caddy/caddy:v1.0.4
ERROR: Service 'caddy' failed to build: manifest for caddy/caddy:v1.0.4 not found: manifest unknown: manifest unknown
i also try with this command
docker build -t openfaas/caddy:latest .
Sending build context to Docker daemon  84.48kB
Please help me out
Caddy v1 is EOL. Please upgrade to Caddy v2.
The official docker image is here: Docker Hub
what if i want to continue with Caddy v1
We don’t support Caddy v1 anymore because it’s EOL. It’s strongly recommended that you upgrade.
Thanks for replying
