Error reverse proxy SSL
I’m trying to configure my Caddy server inside a Docker container to work as a reverse proxy for N8N, my domain is on Netlify, I have an SSL certificate on my website and I’ve never had any problems with the certificate. But I can’t use Caddy to generate a certificate for my subdomain or manage the certificate I already have.
2024-12-09 12:05:09 {"level":"info","ts":1733756709.8090196,"msg":"shutting down apps, then terminating","signal":"SIGTERM"}
2024-12-09 12:05:09 {"level":"warn","ts":1733756709.809091,"msg":"exiting; byeee!! 👋","signal":"SIGTERM"}
2024-12-09 12:05:09 {"level":"info","ts":1733756709.8092082,"logger":"http","msg":"servers shutting down with eternal grace period"}
2024-12-09 12:05:09 {"level":"info","ts":1733756709.810839,"logger":"tls.obtain","msg":"releasing lock","identifier":"flow.technervs.com"}
2024-12-09 12:05:09 {"level":"info","ts":1733756709.813849,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
2024-12-09 12:05:09 {"level":"info","ts":1733756709.8139217,"msg":"shutdown complete","signal":"SIGTERM","exit_code":0}
2024-12-09 12:05:10 {"level":"info","ts":1733756710.760374,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
2024-12-09 12:05:10 {"level":"info","ts":1733756710.761943,"msg":"adapted config to JSON","adapter":"caddyfile"}
2024-12-09 12:05:10 {"level":"warn","ts":1733756710.7619739,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
2024-12-09 12:05:10 {"level":"info","ts":1733756710.7635064,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
2024-12-09 12:05:10 {"level":"info","ts":1733756710.7637384,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
2024-12-09 12:05:10 {"level":"info","ts":1733756710.763767,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
2024-12-09 12:05:10 {"level":"info","ts":1733756710.763825,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000697d00"}
2024-12-09 12:05:10 {"level":"info","ts":1733756710.764178,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
2024-12-09 12:05:10 {"level":"info","ts":1733756710.764269,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 7168 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Buffer-Sizes for details."}
2024-12-09 12:05:10 {"level":"info","ts":1733756710.76442,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
2024-12-09 12:05:10 {"level":"info","ts":1733756710.7645817,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
2024-12-09 12:05:10 {"level":"info","ts":1733756710.7646046,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["flow.technervs.com"]}
2024-12-09 12:05:10 {"level":"info","ts":1733756710.7677777,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
2024-12-09 12:05:10 {"level":"info","ts":1733756710.767843,"msg":"serving initial configuration"}
2024-12-09 12:05:10 {"level":"info","ts":1733756710.7715065,"logger":"tls.obtain","msg":"acquiring lock","identifier":"flow.technervs.com"}
2024-12-09 12:05:10 {"level":"info","ts":1733756710.775764,"logger":"tls","msg":"storage cleaning happened too recently; skipping for now","storage":"FileStorage:/data/caddy","instance":"a2bbb34a-f079-4380-bc95-c0bc939c8fd7","try_again":1733843110.7757616,"try_again_in":86399.999999637}
2024-12-09 12:05:10 {"level":"info","ts":1733756710.7759268,"logger":"tls.obtain","msg":"lock acquired","identifier":"flow.technervs.com"}
2024-12-09 12:05:10 {"level":"info","ts":1733756710.7762156,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"flow.technervs.com"}
2024-12-09 12:05:10 {"level":"info","ts":1733756710.7769787,"logger":"tls","msg":"finished cleaning storage units"}
2024-12-09 12:05:10 {"level":"info","ts":1733756710.7934666,"logger":"http","msg":"waiting on internal rate limiter","identifiers":["flow.technervs.com"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":""}
2024-12-09 12:05:10 {"level":"info","ts":1733756710.7935102,"logger":"http","msg":"done waiting on internal rate limiter","identifiers":["flow.technervs.com"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":""}
2024-12-09 12:05:10 {"level":"info","ts":1733756710.7935202,"logger":"http","msg":"using ACME account","account_id":"https://acme-v02.api.letsencrypt.org/acme/acct/2103233187","account_contact":[]}
2024-12-09 12:05:11 {"level":"info","ts":1733756711.9478254,"logger":"http.acme_client","msg":"trying to solve challenge","identifier":"flow.technervs.com","challenge_type":"http-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
2024-12-09 12:05:12 {"level":"error","ts":1733756712.5702384,"logger":"http.acme_client","msg":"challenge failed","identifier":"flow.technervs.com","challenge_type":"http-01","problem":{"type":"urn:ietf:params:acme:error:connection","title":"","detail":"189.111.248.216: Fetching https://flow.technervs.com:10443/.well-known/acme-challenge/FeC4T21Nhc47a7GU2ghgNg3xnDpow377-nZk5B-yQYs: Invalid port in redirect target. Only ports 80 and 443 are supported, not 10443","instance":"","subproblems":[]}}
2024-12-09 12:05:12 {"level":"error","ts":1733756712.5703006,"logger":"http.acme_client","msg":"validating authorization","identifier":"flow.technervs.com","problem":{"type":"urn:ietf:params:acme:error:connection","title":"","detail":"189.111.248.216: Fetching https://flow.technervs.com:10443/.well-known/acme-challenge/FeC4T21Nhc47a7GU2ghgNg3xnDpow377-nZk5B-yQYs: Invalid port in redirect target. Only ports 80 and 443 are supported, not 10443","instance":"","subproblems":[]},"order":"https://acme-v02.api.letsencrypt.org/acme/order/2103233187/331490823367","attempt":1,"max_attempts":3}
2024-12-09 12:05:14 {"level":"info","ts":1733756714.0264037,"logger":"http.acme_client","msg":"trying to solve challenge","identifier":"flow.technervs.com","challenge_type":"tls-alpn-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
v2
  • OS: Docker Desktop (MacOS)
  • Architecture: x86_64
  • Docker version: 24.0.1
  • Caddy version: 2.6.4
  • Systemd: No
I am using Docker Compose to run Caddy. Below is the command I use to start the services:
docker compose up -d --build
Here is the docker-compose.yml file configuration:
version: '3.8'
  db_storage:
  n8n_storage:
  redis_storage:
  caddy_data:
x-shared: &shared
  restart: always
  image: docker.n8n.io/n8nio/n8n
    - DB_TYPE=postgresdb
    - DB_POSTGRESDB_HOST=postgres
    - DB_POSTGRESDB_DATABASE=$POSTGRES_DB
    - DB_POSTGRESDB_PORT=5432
    - DB_POSTGRESDB_USER=${POSTGRES_NON_ROOT_USER}
    - DB_POSTGRESDB_PASSWORD=${POSTGRES_NON_ROOT_PASSWORD}
    - N8N_ENCRYPTION_KEY=$encryption_key
    - N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS=true
    - N8N_SECURE_COOKIE=true
    - N8N_HOST=$url_editorn8n
    - N8N_EDITOR_BASE_URL=https://$url_editorn8n/
    - WEBHOOK_URL=https://$url_webhookn8n/
    - N8N_PROTOCOL=https
    - NODE_ENV=production
    - EXECUTIONS_MODE=queue
    - N8N_REINSTALL_MISSING_PACKAGES=true
    - N8N_COMMUNITY_PACKAGES_ENABLED=true
    - N8N_NODE_PATH=/home/node/.n8n/nodes
    - QUEUE_BULL_REDIS_HOST=redis
    - QUEUE_BULL_REDIS_PORT=6379
    - QUEUE_BULL_REDIS_DB=2
    - NODE_FUNCTION_ALLOW_EXTERNAL=moment,lodash,moment-with-locales
    - EXECUTIONS_DATA_PRUNE=true
    - EXECUTIONS_DATA_MAX_AGE=336
    - GENERIC_TIMEZONE=America/Sao_Paulo
    - TZ=America/Sao_Paulo
  links:
    - postgres
    - redis
    - n8n_storage:/home/node/.n8n
    - ./local_files:/files
    - n8n_storage:/ca-certificate.crt:/certs/db.crt
  depends_on:
    redis:
      condition: service_healthy
    postgres:
  postgres:
    image: postgres:16
    restart: always
      - POSTGRES_USER
      - POSTGRES_PASSWORD
      - POSTGRES_DB
      - POSTGRES_NON_ROOT_USER
      - POSTGRES_NON_ROOT_PASSWORD
      - db_storage:/var/lib/postgresql/data
      - ./init-data.sh:/docker-entrypoint-initdb.d/init-data.sh
    healthcheck:
      test: ['CMD-SHELL', 'pg_isready -h localhost -U ${POSTGRES_USER} -d ${POSTGRES_DB}']
      interval: 5s
      timeout: 5s
      retries: 10
  redis:
    image: redis:6-alpine
    restart: always
      - redis_storage:/data
    healthcheck:
      test: ['CMD', 'redis-cli', 'ping']
      interval: 5s
      timeout: 5s
      retries: 10
    image: caddy:latest
      - ./caddy_config:/data
      - ./caddy_config:/config
      - ./caddy_config/Caddyfile:/etc/caddy/Caddyfile
  n8n:
    <<: *shared
  n8n-worker:
    <<: *shared
    command: worker
    depends_on:
      - n8n
Here is the Caddyfile I am using:
flow.technervs.com {
    reverse_proxy n8n-1:5678 {
        flush_interval -1
Howdy @technervs, welcome to the Caddy community!
The error here indicates that LetsEncrypt tried to connect to your server but was served a redirect to port 10433.
I observed the same behaviour:
whitestrake at 🌐 orthus in ~
❯ curl -v flow.technervs.com
* Host flow.technervs.com:80 was resolved.
* IPv6: (none)
* IPv4: 189.111.248.216
*   Trying 189.111.248.216:80...
* Connected to flow.technervs.com (189.111.248.216) port 80
* using HTTP/1.x
> GET / HTTP/1.1
> Host: flow.technervs.com
> User-Agent: curl/8.11.0
* Request completely sent off
< HTTP/1.1 307 Temporary Redirect
< Date: Tue, 10 Dec 2024 05:23:13 GMT
< Server: xxxxxxxx-xxxxx
< Location: https://flow.technervs.com:10443/
< Transfer-Encoding: chunked
< Content-Type: text/html; charset=utf-8
< X-Frame-Options: SAMEORIGIN
< Content-Security-Policy: frame-ancestors 'self'; object-src 'self'; script-src 'self' https:   'unsafe-eval' 'unsafe-inline' blob:;
< X-XSS-Protection: 1; mode=block
< X-Content-Type-Options: nosniff
< Strict-Transport-Security: max-age=31536000
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<HTML><HEAD>
<TITLE>307 Temporary Redirect</TITLE>
</HEAD><BODY>
<H1>Temporary Redirect</H1>
The document has moved <A HREF="https://flow.technervs.com:10443/">here</A>.<P>
</BODY></HTML>
* Connection #0 to host flow.technervs.com left intact
It seems like Caddy isn’t listening at this IP address anymore - some other server is.
LetsEncrypt does not allow validation on nonstandard HTTP(S) ports. You will need to fix this.
