1. Caddy version:
> cat /etc/*release
NAME="Oracle Linux Server"
VERSION="9.1"
ID_LIKE="fedora"
PLATFORM_ID="platform:el9"
> uname -a
Linux oracle-linux 5.15.0-6.80.3.1.el9uek.aarch64 #2 SMP Tue Jan 10 11:35:24 PST 2023 aarch64 aarch64 aarch64 GNU/Linux
sudo dnf copr enable @caddy/caddy
sudo dnf install caddy
sudo mkdir -p /etc/caddy ; sudo cp Caddyfile /etc/caddy/
sudo systemctl enable caddy
sudo systemctl start caddy
no modifications
cat /etc/caddy/Caddyfile
localhost {
respond "Hello world!"
localhost:8080 {
file_server browse
3. The problem I’m having / Error messages and/or full log output / What I already tried / Links to relevant resources:
I’m trying to setup caddy, first as a simple file server, on Oracle cloud free tier.
First it seems I hit
Full log of my `systemctl start caddy`
Feb 11 23:51:51 oracle-linux systemd[1]: Starting Caddy...
Feb 11 23:51:51 oracle-linux caddy[6141]: caddy.HomeDir=/var/lib/caddy
Feb 11 23:51:51 oracle-linux caddy[6141]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Feb 11 23:51:51 oracle-linux caddy[6141]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Feb 11 23:51:51 oracle-linux caddy[6141]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Feb 11 23:51:51 oracle-linux caddy[6141]: caddy.Version=v2.6.2 h1:wKoFIxpmOJLGl3QXoo6PNbYvGW4xLEgo32GPBEjWL8o=
Feb 11 23:51:51 oracle-linux caddy[6141]: runtime.GOOS=linux
Feb 11 23:51:51 oracle-linux caddy[6141]: runtime.GOARCH=arm64
Feb 11 23:51:51 oracle-linux caddy[6141]: runtime.Compiler=gc
Feb 11 23:51:51 oracle-linux caddy[6141]: runtime.NumCPU=4
Feb 11 23:51:51 oracle-linux caddy[6141]: runtime.GOMAXPROCS=4
Feb 11 23:51:51 oracle-linux caddy[6141]: runtime.Version=go1.18.6
Feb 11 23:51:51 oracle-linux caddy[6141]: os.Getwd=/
Feb 11 23:51:51 oracle-linux caddy[6141]: LANG=en_US.UTF-8
Feb 11 23:51:51 oracle-linux caddy[6141]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
Feb 11 23:51:51 oracle-linux caddy[6141]: NOTIFY_SOCKET=/run/systemd/notify
Feb 11 23:51:51 oracle-linux caddy[6141]: HOME=/var/lib/caddy
Feb 11 23:51:51 oracle-linux caddy[6141]: LOGNAME=caddy
Feb 11 23:51:51 oracle-linux caddy[6141]: USER=caddy
Feb 11 23:51:51 oracle-linux caddy[6141]: INVOCATION_ID=37143b1cb36647119efe1321feaab3e2
Feb 11 23:51:51 oracle-linux caddy[6141]: JOURNAL_STREAM=8:35768
Feb 11 23:51:51 oracle-linux caddy[6141]: SYSTEMD_EXEC_PID=6141
Feb 11 23:51:51 oracle-linux caddy[6141]: {"level":"info","ts":1676159511.7426624,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Feb 11 23:51:51 oracle-linux caddy[6141]: {"level":"warn","ts":1676159511.7433949,"msg":"Caddyfile input is not formatted; run the 'caddy fmt' command to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
Feb 11 23:51:51 oracle-linux caddy[6141]: {"level":"info","ts":1676159511.7447956,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//[::1]:2019","//127.0.0.1:2019","//localhost:2019"]}
Feb 11 23:51:51 oracle-linux caddy[6141]: {"level":"info","ts":1676159511.745006,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Feb 11 23:51:51 oracle-linux caddy[6141]: {"level":"info","ts":1676159511.745073,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Feb 11 23:51:51 oracle-linux caddy[6141]: {"level":"info","ts":1676159511.7451272,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv1"}
Feb 11 23:51:51 oracle-linux caddy[6141]: {"level":"info","ts":1676159511.7451527,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0x40001b10a0"}
Feb 11 23:51:51 oracle-linux caddy[6141]: {"level":"info","ts":1676159511.7457712,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Feb 11 23:51:51 oracle-linux caddy[6141]: {"level":"info","ts":1676159511.7457967,"logger":"tls","msg":"finished cleaning storage units"}
Feb 11 23:51:51 oracle-linux caddy[6141]: {"level":"warn","ts":1676159511.7587595,"logger":"pki.ca.local","msg":"installing root certificate (you might be prompted for password)","path":"storage:pki/authorities/local/root.crt"}
Feb 11 23:51:51 oracle-linux caddy[6141]: {"level":"info","ts":1676159511.7590356,"msg":"Warning: \"certutil\" is not available, install \"certutil\" with \"apt install libnss3-tools\" or \"yum install nss-tools\" and try again"}
Feb 11 23:51:51 oracle-linux caddy[6141]: {"level":"info","ts":1676159511.7590518,"msg":"define JAVA_HOME environment variable to use the Java trust"}
Feb 11 23:51:51 oracle-linux sudo[6151]: caddy : unable to open /run/sudo/ts/caddy : Permission denied ; PWD=/ ; USER=root ; COMMAND=/bin/tee /etc/pki/ca-trust/source/anchors/Caddy_Local_Authority_-_2023_ECC_Root_291589996991120136616000285617640621002.pem
Feb 11 23:51:51 oracle-linux sudo[6151]: pam_unix(sudo:auth): conversation failed
Feb 11 23:51:51 oracle-linux sudo[6151]: pam_unix(sudo:auth): auth could not identify password for [caddy]
Feb 11 23:51:51 oracle-linux sudo[6151]: PAM audit_open() failed: Permission denied
Feb 11 23:51:53 oracle-linux sudo[6151]: PAM audit_open() failed: Permission denied
Feb 11 23:51:53 oracle-linux caddy[6141]: {"level":"error","ts":1676159513.8407798,"logger":"pki.ca.local","msg":"failed to install root certificate","error":"failed to execute sudo: exit status 1","certificate_file":"storage:pki/authorities/local/root.crt"}
Feb 11 23:51:53 oracle-linux caddy[6141]: {"level":"info","ts":1676159513.841017,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
Feb 11 23:51:53 oracle-linux caddy[6141]: {"level":"info","ts":1676159513.8410473,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
Feb 11 23:51:53 oracle-linux caddy[6141]: {"level":"info","ts":1676159513.8411539,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/lucas-clemente/quic-go/wiki/UDP-Receive-Buffer-Size for details."}
Feb 11 23:51:53 oracle-linux caddy[6141]: {"level":"info","ts":1676159513.8412209,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Feb 11 23:51:53 oracle-linux caddy[6141]: {"level":"info","ts":1676159513.841267,"logger":"http","msg":"enabling HTTP/3 listener","addr":":8080"}
Feb 11 23:51:53 oracle-linux caddy[6141]: {"level":"info","ts":1676159513.8413582,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0x40001b10a0"}
Feb 11 23:51:53 oracle-linux caddy[6141]: Error: loading initial config: loading new config: http app module: start: listen udp :8080: bind: permission denied
Feb 11 23:51:53 oracle-linux systemd[1]: caddy.service: Main process exited, code=exited, status=1/FAILURE
Feb 11 23:51:53 oracle-linux systemd[1]: caddy.service: Failed with result 'exit-code'.
Feb 11 23:51:53 oracle-linux systemd[1]: Failed to start Caddy.
So I tried the workaround suggested there, first “adding to sudoers” (which should be wheel
on this system), but sudo usermod -aG wheel caddy
did not change anything, then the trust
thing:
sudo HOME=~caddy caddy trust
but I get Error: requesting CA info: performing request: Get “http://localhost:2019/pki/ca/local”: dial tcp [::1]:2019: connect: connection refused
Any tips on solving this one is welcome, I understand port 2019 should be exposed by caddy, but it’s not started because of the certificate issue right?
