v2.5.1 h1:bAWwslD1jNeCzDa+jDCNwb8M3UJ2tPa8UZFFzPVmGKs=
Ubuntu 20.04 LTS on Windows WSL2
caddy is built by xcaddy with current security module from GitHub - greenpau/caddy-security: 🔐 Authentication, Authorization, and Accounting (AAA) App and Plugin for Caddy v2. 💎 Implements Form-Based, Basic, Local, LDAP, OpenID Connect, OAuth 2.0 (Github, Google, Facebook, Okta, etc.), SAML Authentication. MFA/2FA with App Authenticators and Yubico. 💎 Authorization with JWT/PASETO tokens. 🔐 · GitHub
export OKTA_DOMAIN=dev-9014393.okta.com
sudo caddy run -config Caddyfile_okta
not used.
d. My complete Caddyfile:
order authenticate before respond
order authorize before basicauth
security {
oauth identity provider okta {
realm okta
driver okta
domain_name {env.OKTA_DOMAIN}
client_id <myclientid>
client_secret <myclientsecret>
server_id default
scopes openid email profile groups
authentication portal myportal {
crypto default token lifetime 3600
crypto key sign-verify 383aca9a-1c39-4d7a-b4d8-67ba4718dd3f
enable identity provider okta
cookie domain myapp.local
ui {
links {
"My Identity" "whoami" icon "las la-user"
transform user {
match realm okta
action add role authp/user
ui link "My Website" https://myapp.local icon "las la-star"
authorization policy mypolicy {
set auth url https://myapp.local/auth
allow roles authp/user
validate bearer header
inject headers with claims
myapp.local {
tls internal
route /auth* {
authenticate with myportal
route {
authorize with mypolicy
respond "myapp is running" 200
After successfully setup single sign-on with okta, I am trying to replace domain name, client id and client secret in Caddyfile from plain text to environment variables. First attemp with {env.OKTA_DOMAIN} I got ERROR_REPLACEMENT
2022/05/31 13:06:12.893 INFO using provided configuration {"config_file": "Caddyfile_okta", "config_adapter": ""}
2022/05/31 13:06:12.895 WARN Caddyfile input is not formatted; run the 'caddy fmt' command to fix inconsistencies {"adapter": "caddyfile", "file": "Caddyfile_okta", "line": 2}
2022/05/31 13:06:12.897 INFO admin admin endpoint started {"address": "tcp/localhost:2019", "enforce_origin": false, "origins": ["//localhost:2019", "//[::1]:2019", "//127.0.0.1:2019"]}
2022/05/31 13:06:12.897 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc00035d180"}
2022/05/31 13:06:12.897 INFO http server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2022/05/31 13:06:12.897 INFO http enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
2022/05/31 13:06:12.898 INFO security provisioning app instance {"app": "security"}
2022/05/31 13:06:12.938 DEBUG security fetchMetadataURL failed {"identity_provider_name": "okta", "error": "failed to fetch metadata for OAuth 2.0 authorization server: Get \"https://ERROR_REPLACEMENT/oauth2/default/.well-known/openid-configuration?client_id=<myclientid>\": dial tcp: lookup ERROR_REPLACEMENT on 8.8.8.8:53: no such host"}
2022/05/31 13:06:12.939 ERROR security failed provisioning app server instance {"app": "security", "error": "server initialization failed: failed configuring identity provider: failed to fetch metadata for OAuth 2.0 authorization server: Get \"https://ERROR_REPLACEMENT/oauth2/default/.well-known/openid-configuration?client_id=<myclientid>\": dial tcp: lookup ERROR_REPLACEMENT on 8.8.8.8:53: no such host"}
2022/05/31 13:06:12.939 INFO tls.cache.maintenance stopped background certificate maintenance {"cache": "0xc00035d180"}
run: loading initial config: loading new config: loading http app module: provision http: server srv0: setting up route handlers: route 0: loading handler modules: position 0: loading module 'subroute': provision http.handlers.subroute: setting up subroutes: route 0: loading handler modules: position 0: loading module 'subroute': provision http.handlers.subroute: setting up subroutes: route 0: loading handler modules: position 0: loading module 'subroute': provision http.handlers.subroute: setting up subroutes: route 0: loading handler modules: position 0: loading module 'authenticator': provision http.handlers.authenticator: loading security app module: provision security: server initialization failed: failed configuring identity provider: failed to fetch metadata for OAuth 2.0 authorization server: Get "https://ERROR_REPLACEMENT/oauth2/default/.well-known/openid-configuration?client_id=<myclientid>": dial tcp: lookup ERROR_REPLACEMENT on 8.8.8.8:53: no such host
I’ve read this wiki Variables in Caddyfile but still not find a solution.
The example Caddyfile that I followed:
https://github.com/authp/authp.github.io/blob/main/assets/conf/oauth/okta/Caddyfile
