After installing CaddyServer on Ubuntu 22.04.4 LTS (GNU/Linux 6.5.0-1014-aws x86_64) add test the first certificate I’m keep getting error.
{"level":"debug","ts":1711424877.244184,"logger":"http.stdlib","msg":"http: TLS handshake error from 185.149.254.53:60051: failed storage check: open /etc/caddy_data/rw_test_7465987084182321390: read-only file system - storage is probably misconfigured"}
v2.7.6
sudo apt update
sudo apt install caddy
sudo mkdir /etc/caddy_data
sudo chmod -R 777 /etc/caddy_data
sudo chown -R caddy:caddy /etc/caddy_data
sudo systemctl reload caddy
storage file_system {
root /etc/caddy_data
# TLS Options
cert_issuer acme https://acme-v02.api.letsencrypt.org/directory
email noam@example.com
on_demand_tls {
ask https://www.example.com/domain.php
# Disable redirect
auto_https disable_redirects
:443 {
on_demand
#redir http://www.{host}{uri}
respond "Welcome to the testing page! {host}"
