Error obtaining home directory, please define environment variable HOME. caddy2 cannot run
install caddy bin
alpine:edge
dockerfile deploy container
/usr/local/bin/caddy run --config /etc/caddy/Caddyfile --adapter caddyfile
FROM alpine:edge
RUN  apk update && \
     apk add --no-cache --virtual .build-deps ca-certificates nss-tools curl && \
     mkdir /tmp/v2ray && \
     mkdir /tmp/caddy && \
     curl -L -H "Cache-Control: no-cache" -o /tmp/v2ray/v2ray.zip https://github.com/v2fly/v2ray-core/releases/latest/download/v2ray-linux-64.zip && \
     unzip /tmp/v2ray/v2ray.zip -d /tmp/v2ray && \
     install -m 755 /tmp/v2ray/v2ray /usr/local/bin/v2ray && \
     install -m 755 /tmp/v2ray/v2ctl /usr/local/bin/v2ctl && \
     v2ray -version && \
     curl -L -H "Cache-Control: no-cache" -o /tmp/caddy/caddy https://github.com/caddyserver/caddy/releases/download/v2.4.3/caddy_2.4.3_linux_arm64.tar.gz && \
     tar -zxvf /tmp/caddy/caddy.tar.gz -C /tmp/caddy && \
     install -m 755 /tmp/caddy/caddy /usr/local/bin/caddy && \
     caddy version && \
     rm -rf /tmp/caddy && \
     rm -rf /tmp/v2ray && \
     rm -rf /var/cache/apk/* && \
     apk del .build-deps
COPY etc/ /conf
ADD config.sh /config.sh
RUN chmod +x /config.sh
CMD /config.sh
I have deleted parts of the files for confidentiality reasons
:$PORT
root * ******
file_server browse
tls internal
    Permissions-Policy interest-cohort=()
    X-Robots-Tag none
    X-Frame-Options DENY
basicauth ****** {
@websocket****** {
    header Connection *Upgrade*
    header Upgrade    websocket
    path ******
reverse_proxy @websocket****** ******
error obtaining home directory, please define environment variable HOME.
{ā€œlevelā€:ā€œwarnā€,ā€œtsā€:1629167856.1931417,ā€œmsgā€:ā€œunable to determine directory for user configuration; falling back to current directoryā€,ā€œerrorā€:ā€œneither $XDG_CONFIG_HOME nor $HOME are definedā€}
using caddy version v2.3 ~ v2.1
Still prompted Error obtaining home directory, please define environment variable HOME.
This means the $HOME environment variable isn’t set.
You can verify this easily enough. What is the output when you add the --environ flag to your run command?
$home variable set to caddy work folder or caddy webroot folder ?
I strongly recommend using our official Docker image, which is properly set up. See it on Docker Hub
Try adding the following code in the dockerfile (in addition, please use the official docker image as much as possible. It is not a good idea to run v2ray and caddy in the same docker container).
ē„ä½ å„½čæ :crazy_face:
# See https://caddyserver.com/docs/conventions#file-locations for details
ENV XDG_CONFIG_HOME /config
ENV XDG_DATA_HOME /data
XDG_CONFIG_HOME & XDG_DATA_HOME error clear.
but still prompted variable HOME error
docker image it works
ta
