Error "module not registered: caddy.logging.encoders.single_field" encountered after upgrading to 2.5.0
2.5.0
Debian 9 x64
systemctl restart caddy.service
        http_port 80
        https_port 443
        admin off
        key_type p384
my.domain {
                X-XSS-Protection "1; mode=block;"
                X-Frame-Options DENY
        root * /var/lib/caddy/my.domain
        tls my@mailbox {
                protocols tls1.3
                ciphers TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384 TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256 TLS_AES_128_GCM_SHA256 TLS_AES_256_GCM_SHA384 TLS_CHACHA20_POLY1305_SHA256
                output file /var/log/access.log
        reverse_proxy * proxy.domain {
                header_up Host proxy.domain
                header_up X-Real-IP {http.request.remote.host}
                header_up X-Forwarded-For {http.request.remote.host}
                header_up X-Forwarded-Proto {http.request.scheme}
                header_down Set-Cookie proxy.domain my.domain
        @xray_websocket {
                path /market_investigation
                header Connection *Upgrade*
                header Upgrade websocket
        reverse_proxy @xray_websocket 127.0.0.1:2048
Unable to start caddy.service .
● caddy.service - Caddy
Active: failed (Result: exit-code) since Wed 2022-04-27 00:02:43 HKT; 1min 49s ago
Docs: Welcome — Caddy Documentation
Process: 1927 ExecStart=/usr/local/bin/caddy run --environ --config /etc/caddy/Caddyfile (code=exited, status=1/FAILURE)
Main PID: 1927 (code=exited, status=1/FAILURE)
Apr 27 00:02:43 caddy[1927]: HOME=/var/lib/caddy
Apr 27 00:02:43 caddy[1927]: LOGNAME=caddy
Apr 27 00:02:43 caddy[1927]: USER=caddy
Apr 27 00:02:43 caddy[1927]: INVOCATION_ID=2272c449a52d4156b25c1ff438ff4fa8
Apr 27 00:02:43 caddy[1927]: JOURNAL_STREAM=9:81627
Apr 27 00:02:43 caddy[1927]: {“level”:“info”,“ts”:1650988963.8553007,“msg”:“using provided configuration”,“config_file”:“/etc/caddy/Caddyfile”,“config_adapter”:“”}
Apr 27 00:02:43 caddy[1927]: run: adapting config using caddyfile: parsing caddyfile tokens for ‘log’: /etc/caddy/Caddyfile:27 - Error during parsing: getting module named ‘caddy.logging.encoders.single_field’: module not registered: caddy.logging.encoders.single_field
Apr 27 00:02:43 systemd[1]: caddy.service: Main process exited, code=exited, status=1/FAILURE
Apr 27 00:02:43 systemd[1]: caddy.service: Failed with result ‘exit-code’.
Apr 27 00:02:43 systemd[1]: Failed to start Caddy.
Deleted the row of “format single_field common_log” content of Caddyfile .
Yes, it was removed. It was deprecated for many versions. See the release notes:
Ahhh , all right , it seemed this changes didn’t make any difference lol .
