Error handling using http.cat and reverse proxy not functioning (or I'm stupid, one of the two)
official systemd unit from the github repo, no alterations
ubuntu 18.04 lts, systemd controlled start
systemctl start caddy
official from caddy server github repo
(gen) {
    try_files {path} {path}.html
    php_fastcgi unix//var/run/php/php7.4-fpm.sock
    handle_errors {
    rewrite * /{http.error.status_code}
    reverse_proxy https://http.cat
    format console
    output file /var/log/caddy.log {
        roll_size 25mb
        roll_keep 20
        roll_keep_for 720h
(dns) {
    dns digitalocean redacted
(header-gen) {
    Strict-Transport-Security "max-age=31536000; includeSubdomains; preload"
    X-Frame-Options "DENY"
eiphax.tech {
    Strict-Transport-Security "max-age=31536000; preload"
    root * /var/www/eipdox
    import gen
facts.eiphax.tech {
    import header-gen
    root * /var/www/eipdox/facts
    import gen
soultrader.net.au {
    import header-gen
    root * /var/www/st
    import gen
blog.eiphax.tech {
    import header-gen
    root * /var/www/blog
    import gen
album.eiphax.tech {
    import header-gen
    root * /var/www/lychee/public
    import gen
bin.eiphax.tech {
    import header-gen
    root * /var/www/eipbin
    import gen
3ds.eiphax.tech {
    import header-gen
    root * /var/www/eipdox/3ds
    import gen
http://wiiu.eiphax.tech {
    root * /var/www/eipdox/wiiu
    import gen
https://wiiu.eiphax.tech {
    import gen
nx.eiphax.tech {
    import header-gen
    root * /var/www/eipdox/nx
    import gen
nintendohomebrew.com {
    root * /var/www/eipdox/nh
    import gen
http://bhax.nintendohomebrew.com {
    root * /var/www/bhax/web/nbhax
bfm.nintendohomebrew.com {
    import header-gen
    root * /var/www/eipdox/nh/seed
    reverse_proxy localhost:8082
    level error
    format console
    output file /var/log/bfm_error.log {
        roll_size 25mb
        roll_keep 20
        roll_keep_for 720h
http://part1dumper.nintendohomebrew.com https://part1dumper.nintendohomebrew.com {
    reverse_proxy localhost:8081
shitpost.lol {
    import header-gen
    root * /var/www/sp
    import gen
hacc.me please.hacc.me {
    import header-gen
    root * /var/www/hacc
    import gen
friigaemsworld.com {
    import header-gen
    root * /var/www/frigam
    import gen
uwu.tax {
    import header-gen
    root * /var/www/uwu
    import gen
conversation.id {
    import header-gen
    root * /var/www/conv
    import gen
puebes.com {
    import header-gen
    root * /var/www/puebes
    import gen
I’m trying to politely ask Caddy to serve error images from https://http.cat in response to http errors.
It just seems to endlessly redirect and/or rewrites the status code to the base domain, rather than reverse proxying it to http.cat. See https://uwu.tax/thispagedoesnotexist.html for an example.
as above. caddy logs just contain the request:
1.60534013800369e+09	info	http.log.access.log17	handled request	{"request": {"remote_addr": "115.129.10.61:50530", "proto": "HTTP/2.0", "method": "GET", "host": "uwu.tax", "uri": "/404/ghost","headers": {"Sec-Fetch-Mode": ["navigate"], "Sec-Fetch-User": ["?1"], "Cache-Control": ["max-age=0"], "Dnt": ["1"], "Upgrade-Insecure-Requests": ["1"], "User-Agent": ["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/86.0.4240.198 Safari/537.36"], "Accept": ["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"], "Sec-Fetch-Site": ["cross-site"], "Sec-Fetch-Dest": ["document"], "Accept-Encoding": ["gzip, deflate, br"], "Accept-Language": ["en-US,en;q=0.9"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "h2", "proto_mutual": true, "server_name": "uwu.tax"}}, "common_log": "115.129.10.61 - - [14/Nov/2020:18:48:58 +1100] \"GET /404/ghost HTTP/2.0\" 301 178", "duration": 0.0002685, "size": 178, "status": 301, "resp_headers": {"X-Frame-Options": ["DENY"], "X-Xss-Protection": ["1; mode=block"], "Date": ["Sat, 14 Nov 2020 07:48:57 GMT"], "Server": ["Caddy", "nginx/1.18.0 (Ubuntu)"], "Strict-Transport-Security": ["max-age=31536000; includeSubdomains; preload"], "Location": ["https://uwu.tax/404/ghost"], "Content-Type": ["text/html"], "X-Content-Type-Options": ["nosniff"], "Content-Length": ["178"]}}
unfortunately i’m not fully sure what i’m doing, so i haven’t made any changes.
got the handle errors block from here
I think you might need to override the Host header when proxying to it. It likely expects the domain to match. By default, Caddy passes the Host of the original request through.
	handle_errors {
		reverse_proxy https://http.cat {
			header_up Host http.cat
Hi Francis,
Thanks for saving me again.
    handle_errors {
Could this example block be updated in the docs? It’s clearly not a massive issue, but may save an idiot like me in the future.
I recommend you use the caddy fmt command to fix the indentation in your config, it makes it much easier to read.
Also there is an example that should cover this already:
Set the upstream Host header to the address of the upstream (by default, it will retain its original, incoming value):
Sorry… it’s formatted more for me, but I should probably get used to prettier formats.
I’m (now) aware of the example in reverse_proxy, I was more referring to the one in handle_errors, as it seems to me that for the error handler to work as exemplified it needs the extra Host directive.
