v2.4.5 h1:P1mRs6V2cMcagSPn+NWpD+OEYUYLIf6ecOa48cFGeUg=
systemd
Arch Linux, executing the binary
./caddy run -config Caddyfile
N/A
:8081 {
tls internal
reverse_proxy https://caddyserver.com {
header_up -Accept-Encoding
@status_code {
status 200
expression `{http.reverse_proxy.header.server} == "Caddy"`
redir @status_code https://google.com
I’m getting an error
2021/10/03 01:39:25.105 INFO using provided configuration {"config_file": "Caddyfile", "config_adapter": ""}
run: adapting config using caddyfile: parsing caddyfile tokens for 'reverse_proxy': Caddyfile:11 - Error during parsing: unrecognized response matcher expression
None, as I cannot find any info about response matcher. Only request matcher is available in docs.
expression cannot be used to match responses. The only ones currently available are status and header, as described in the docs:
Also, you need to define a handle_response block, under which you can define handler directives (like redir).
That said, handle_response currently has a bug that prevents it from working with any requests that have a non-empty response body. So it’s not currently possible to do what you’re trying to do, unfortunately.
opened 02:42AM - 22 Aug 21 UTC
closed 06:00PM - 18 Oct 21 UTC
bug
Following the [docs for `reverse_proxy` directive with `handle_response`](https:… //caddyserver.com/docs/caddyfile/directives/reverse_proxy#intercepting-responses) on a very basic JSON response endpoint results in failure, but modifying the header elsewhere in Caddy works as expected.
**Caddyfile (v2.4.3):**
```Caddyfile
# Works:
#header Cache-Control "max-age=10"
reverse_proxy localhost:8000 {
handle_response {
# Errors:
# Works:
#header_down Cache-Control "max-age=10"
**Error logged:**
2021/08/22 02:34:00.645 ERROR http.handlers.reverse_proxy reading from backend {"error": "http: read on closed response body"}
2021/08/22 02:34:00.645 ERROR http.handlers.reverse_proxy aborting with incomplete response {"error": "http: read on closed response body"}
The upstream still received the request and responded no differently AFAIK, in the web browser network tools Caddy has sent a response header but omitted the body.
For added context, intention was to match on `Content-Type application/json` rather than the URI; but AFAIK this is only available via the response, and thus can only be matched within `handle_response`? As the response matcher is not required to reproduce the error I have excluded it.
