Error during parsing: Unexpected EOF
1. Caddy version (2):
I run caddy in a compose file;
entrypoint:
    - caddy
    - run
    command:
    - --config=/etc/caddy/Caddyfile
    - --adapter=caddyfile
        #debug
        admin off
                level INFO
                format json
                output stderr
        root * /home
                level INFO
                format json
                output stdout
        encode * gzip zstd
        @api_ab {
                path /dl
                path /dl/*
                path /admin
                path /admin/*
                path /api/v1
                path /api/v1/*
        @api_m {
                path /api/v1/m
                path /api/v1/m/*
        @api_me {
                path /me
                path /me/*
        @api_s {
                path /s
                path /s/*
        @api_in {
                path /in
                path /in/*
        @qa_auth {
                method GET
                path *
                query qa=auth
        route {
                respond @api_ab invalid 410 {
                        close
                respond @api_m invalid 410 {
                        close
                respond @api_me invalid 410 {
                        close
                respond @api_in invalid 410 {
                        close
                respond @api_s invalid 410 {
                        close
                handle @qa_auth {
                        basicauth @qa_auth bcrypt qa.fincompare.de {
                                finstaging <trimmed key for privacy>
                        rewrite * /headers
                        respond * "granted" 200 {
                                close
                        # for debugging locally
                        #reverse_proxy https://httpbin.org {
                        #       header_up Host httpbin.org
                handle /health {
                        respond * 200 {
                                body "okay"
                                close
                handle * {
                        try_files {path} {path}/ /{$INDEX:index.html}?{query}
                        file_server * {$BROWSE:browse} {
                                root {http.vars.root}
                                index {$INDEX:index.html}
        handle_errors {
                respond "{http.error.status_code} {http.error.status_text}"
                #rewrite * /{http.error.status_code}
                #reverse_proxy https://http.cat {
                        #debug
                        admin off
                                level INFO
                                format json
                                output stderr
                        root * /home
                                level INFO
                                format json
                                output stdout
                        encode * gzip zstd
                        @api_fc-app {
                                path /dl
                                path /dl/*
                                path /admin
                                path /admin/*
                                path /api/v1
                                path /api/v1/*
                        @api_m {
                                path /api/v1/m
                                path /api/v1/m/*
                        @api_me {
                                path /me
                                path /me/*
                        @api_s {
                                path /s
                                path /s/*
                        @api_in {
                                path /in
                                path /in/*
                        @qa_auth {
                                method GET
                                path *
                                query qa=auth
                        route {
                                        close
                                        close
                                        close
                                        close
                                        close
                                handle @qa_auth {
                                        rewrite * /headers
                                                close
                                handle /health {
                                        respond * 200 {
                                                body "okay"
                                                close
                                handle * {
                        handle_errors {
                                #       header_up Host http.cat
Upon restart of services, caddy does not validate the caddy config and throws following error.
run: adapting config using caddyfile: /etc/caddy/Caddyfile:196 - Error during parsing: Unexpected EOF
I tried doing caddy fmt and before this, I was getting error such as the following;
Caddyfile:50 - Error during parsing: Unexpected next token after '{' on same line
Maybe you have created the Caddyfile in windows and the line endings are windows line endings and not unix line endings.
Try to save the Caddyfile with LF instead of CRLF, it’s just a guess.
Start by removing bits of config one chunk at a time until it works. You can narrow down which part is causing the issue.
