Error code: SSL_ERROR_RX_RECORD_TOO_LONG
1. Caddy version:
addy version
Installed Caddy on a mint 21 linux VM running on a windows PC.
Followed install docs for Ubuntu packages.
Caddy is running on startup.
Changed Caddyfile in /etc/caddy and run caddy reload.
Mint 21, VM on windows PC host
Used caddy reload to reload new Caddyfile
caddy reload
# domain name.
:8555 {
	reverse_proxy localhost:8055
I am running directus on http://localhost:8055. I can access this both locally and from the host. The VM is set to share the host IP.
But if I try to access https://localhost:8555 on the VM or https://vm-name:8555 within firefox, I get
An error occurred during a connection to mint21-wolfsberg:8555. SSL received a record that exceeded the maximum permissible length.
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
Please contact the web site owners to inform them of this problem.
So I stopped the caddy server, and used
caddy reverse-proxy --from :8555 --to 8055
on the command line
Then run curl . Output below
$ curl -v 127.0.0.1:8055
*   Trying 127.0.0.1:8055...
* Connected to 127.0.0.1 (127.0.0.1) port 8055 (#0)
> GET / HTTP/1.1
> Host: 127.0.0.1:8055
> User-Agent: curl/7.81.0
< HTTP/1.1 302 Found
< Content-Security-Policy: script-src 'self' 'unsafe-eval';worker-src 'self' blob:;child-src 'self' blob:;img-src 'self' data: blob: https://cdn.directus.io;media-src 'self' https://cdn.directus.io;connect-src 'self' https://*;default-src 'self';base-uri 'self';font-src 'self' https: data:;form-action 'self';frame-ancestors 'self';object-src 'none';script-src-attr 'none';style-src 'self' https: 'unsafe-inline'
< X-Powered-By: Directus
< Vary: Origin, Accept
< Access-Control-Allow-Credentials: true
< Access-Control-Expose-Headers: Content-Range
< Location: ./admin
< Content-Length: 29
< Date: Thu, 09 Feb 2023 11:55:35 GMT
< Connection: keep-alive
< Keep-Alive: timeout=5
 Connection #0 to host localhost left intact
Found. Redirecting to ./adminj
And caddy log
$ caddy reverse-proxy --from :8555 --to 8055
2023/02/09 11:53:59.109	WARN	admin	admin endpoint disabled
2023/02/09 11:53:59.111	INFO	http.log	server running	{"name": "proxy", "protocols": ["h1", "h2", "h3"]}
Caddy proxying http://:8555 -> 8055:80
2023/02/09 11:53:59.112	INFO	tls	cleaning storage unit	{"description": "FileStorage:/home/jnorris/.local/share/caddy"}
2023/02/09 11:53:59.116	INFO	tls	finished cleaning storage units
2023/02/09 11:53:59.117	INFO	tls.cache.maintenance	started background certificate maintenance	{"cache": "0xc000140ee0"}
So from looking at the caddy output, there was no reaction to curl. The log output occured when I started caddy.
But looking at curl, it did find directus. And redirected to directus/admin. Do I have to create a certificate? From the caddy docs, I thought it created a cert so I may be misunderstanding what is happening.
In summary, I want caddy to take an https address and pass that to a http address. Is directus rejecting this? Is this a dieectus problem?
Also the output in curl does not include the output within the browser regarding ssl record too long.
It seems I might require “tls internal” as part of the 8555 block in the caddyfile?
Have added that and identical result.
So perhaps not?
That’s because your curl command was issued directly to the upstream service (port 8055) and not Caddy (port 8555), bypassing Caddy. As for the record length issue…
The reason you can’t connect to https://*:8555 is because Caddy is serving HTTP on this port. The “SSL record” is too long because Caddy simply isn’t responding with proper HTTPS.
Caddy can’t easily manage a certificate for a site for which the domain name is not known. You would require On-Demand TLS for that functionality.
See:
https://caddyserver.com/docs/automatic-https#on-demand-tls
Alternatively, if you set a hostname (e.g. caddy reverse-proxy --from localhost:8555 --to :8055), it should use internal TLS, and setting a full domain name should see it attempting to requisition a certificate from a public service.
Further, because your caddy reverse-proxy command didn’t have a colon(:) in front of the upstream port, it assumed (as you can see in the above quoted Caddy log detail) that 8055 is the hostname and then proxied to the default port 80 on that host. You’ll need to specify the full --to :8055 to ensure Caddy knows you’re talking about a port, here.
Hi Matthew,
the only thing I can think of with curl 8055 is “D’oh”. Yes that was pretty dumb.
The caddyfile is now
:8555 {
	tls internal
And curl now …
$ curl -v https://localhost:8555
*   Trying 127.0.0.1:8555...
* Connected to localhost (127.0.0.1) port 8555 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
*  CApath: /etc/ssl/certs
* (5454) (IN), , Unknown (72):
* error:0A00010B:SSL routines::wrong version number
* Closing connection 0
curl: (35) error:0A00010B:SSL routines::wrong version number
So I googled on “SSL routines::wrong version number” and there was a sugestion to use http://localhost:port. And …
$ curl -v http://localhost:8555
> GET / HTTP/1.1
> Host: localhost:8555
< Date: Fri, 10 Feb 2023 09:32:41 GMT
< Location: ./admin
< Server: Caddy
did “work”. The browser worked too - I got the directus page.
But this is not https.
Looking at the “Quick starts → reverse proxy” docs, it says that
caddy reverse-proxy --from :2080 --to :9000
curl -v 127.0.0.1:2080
will work. Then for https
caddy reverse-proxy --to :9000
and this will go to port 443. But I want 8555. So I tried
caddy reverse-proxy --from:8555 --to:8055 --internal-certs
and that started but again got the SSL routines: wrong version number. Though the log does say
2023/02/10 09:54:25.082	WARN	admin	admin endpoint disabled
2023/02/10 09:54:25.083	WARN	http	automatic HTTPS is completely disabled for server	{"server_name": "proxy"}
So in summary, it is safe to say I am confused.
Just to add
suggests they may be an error in curl which has been fixed in a later version.
Of course, browser still fails with the SSL_ERROR_RX_RECORD_TOO_LONG too long
Any ideas on this?
This is serving Caddy over HTTP, not HTTPS. So you cannot use https://localhost to connect to it.
Like @Whitestrake said, you must use a domain name if you want HTTPS.
OK - so the domain name examples in the doc were not examples. I need a domain name. That really helps so many thanks.
No doubt I will hit more problems as I continue my caddy journey.
And it’s working.
So I used vm-name:8555 { … }
Many thanks to @Whitestrake and @francislavoie for your help and patience.
