We have a vm running an older node application that tries to post data to a remote caddy server. The node application complains → ‘Error: certificate has expired’. Which is not true and if I understand this correctly it has to do with the way letsencrypt issues certificates and that older javascript libs can not understand it correctly.
I find online that it has to do with in what way you issue the letsencrypt certificate and that there is a flag --preferred-chain that can be used to issue the certificate differently and make it work with older javascript libs aswell. I don’t understand this fully but it has to do with -preferred-chain ISRG Root X1 it seems.
I hope someone can make sense of my explanation above.
Is there a way to make caddy issue certificates with another -preferred-chain so that it works with older versions of axios or similar.
If so how to I reissue a correct cert?
Thank you
