Hi guys! It’s me again… I hope i’m not getting on your nerves. This is (hopefully) the last issue I need to get sorted to be happy with my home network setup.
Custom built docker image with cloudflare dns
Dockerfile
FROM caddy:builder AS builder
RUN xcaddy build \
FROM caddy:latest
Raspberry Pi 3 with docker.
docker-compose -f caddycloudflare/docker-compose.yml up -d
version: "3.8"
image: caddy_cloudflare:1.0
hostname: caddy
env_file:
- ../.env
# Add CLOUDFLARE_API_TOKEN to secret.env
# Token permissions:
# (Zone/DNS/EDIT)
# (Zone/Zone/Read)
- ./secret.env
- ./data:/data
- ./config:/config
default:
external:
# External
portainer.{$DOMAIN} {
reverse_proxy {$IP_PORTAINER}:9000
home.{$DOMAIN} {
reverse_proxy {$IP_HOMEASSISTANT}:8123
# Internal
*.lan.{$DOMAIN} {
tls MYEMAIL@gmail.com {
dns cloudflare {$CLOUDFLARE_API_TOKEN}
@unifi host unifi.lan.{$DOMAIN}
handle @unifi {
reverse_proxy {$IP_UNIFI}:8443 {
tls_insecure_skip_verify
@udm host udm.lan.{$DOMAIN}
handle @udm {
reverse_proxy {$IP_UNIFI}:443 {
redir / /login
@home host home.lan.{$DOMAIN}
handle @home {
@portainer host portainer.lan.{$DOMAIN}
handle @portainer {
@pihole host pihole.lan.{$DOMAIN}
handle @pihole {
reverse_proxy {$IP_PIHOLE}:8080
redir / /admin
# For anything else, falls through to this:
respond "404 bruh." 404 {
close
I have my routers domain set to lan.mydomain.com and have pi-hole running as a local DNS server that routes certain subdomains of this domain to the rasperry pi running caddy.
An an example, I have a DNS entry in pi-hole for home.lan.mydomain.com and it sends that to 192.168.1.100 which caddy routes over to the machine (which turns out to be itself) running home assistant on port 8123.
The reason I set it up this way is because I want to be able to type home/ into my browser and hit that page. This should work because when i type home/ into the browser my computer is configured by my routers DHCP to append the search domain lan.silmanserver.net. And indeed, when I type home/ into my browser i can see a log on my Pi-Hole:
Oct 27 18:50:44 dnsmasq[21750]: query[A] home.lan.mydomain.com from 192.168.1.173
Oct 27 18:50:44 dnsmasq[21750]: /etc/pihole/custom.list home.lan.mydomain.com is 192.168.1.100
So this side of things seems to be working great.
But when I do type home/ into my browser and hit enter I am me with ERR_SSL_PROTOCOL_ERROR and when i click on the top left icon (an i in a circle) next to the omnibox i see “Your connection to this site is not secure.”
I have set up a wildcard cert for lan.mydomain.net which I know is working because if i type home.lan.mydomain.com into the browser everything works awesomely and i have the padlock and I can click it to see my wildcard cert shown.
I checked all my other domains in the caddy file: portainer, unifi, udm, pihole. They all show the exact same symptoms. They work with their fully qualified domain names typed into the browser but not if i do the shorthand and let my search-domain do the rest of the work.
My intuition is that the host field is the problem because its Host: home instead of Host: home.lan.mydomain.com. But I don’t actually know how SSL certs work so i’m just taking a stab in the dark; do they need the host to match exactly?
If the host it he problem I might be in big trouble because i think caddy only gets certs for host domains and there is no way to get a wildcard cert to match home since i need a domain.tld that i own.
EDIT: Tried with firefox, same thing but firefox calls this error SSL_ERROR_INTERNAL_ERROR_ALERT
I think this must be caused by the host not matching but i have no idea why. I was under the impression that the search domain / dns suffix was appended when i typed a domain into the browser.
EDIT 2 : I guess i lacked some understanding of how the host header field works. So now i’m thinking i need to have caddy match home and redirect it to home.lan.mydomain.com. Hopefully I can figure that out and it actually solves the problem (and works with tls).
EDIT 3:
I tried adding this
@home_short host home
handle @home_short{
right above the *.lan.{$DOMAIN} block
But it yielded this error when booting the docker
{"level":"info","ts":1603856803.015378,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
run: adapting config using caddyfile: cannot define a matcher outside of a site block: '@home_short'
but if i tried to make a home block like this
home {
I get another error because obviously tls won’t work on this host
{"level":"error","ts":1603856987.33924,"logger":"tls.obtain","msg":"will retry","error":"[home] Obtain: [home] creating new order: request to https://acme-v02.api.letsencrypt.org/acme/new-order failed after 1 attempts: HTTP 400 urn:ietf:params:acme:error:rejectedIdentifier - Error creating new order :: Cannot issue for \"home\": Domain name needs at least one dot (ca=https://acme-v02.api.letsencrypt.org/directory)","attempt":1,"retrying_in":60,"elapsed":0.986014299,"max_duration":2592000}
EDIT 4:
Defined a block like this to disable automatic https for just this:
http://home {
redir https://home.lan.{$DOMAIN}
but now i’m back to the original ERR_SSL_PROTOCOL_ERROR error. The same thing happens if i try to use reverse_proxy {$IP_HOMEASSISTANT}:8123 instead of redir https://home.lan.{$DOMAIN}
EDIT 5:
AAAAAAAAAND SOLVED.
http://home {
just need to add these for each short URL i want. it doesn’t preserve the cool short URL but i guess that’s okay.
