ERR_SSL_PROTOCOL_ERROR — both with TLS and TLS off, curl gives mixed results
Caddy v1.0.4
I use the hook.service plugin
The domain is hosted by Google Domains.
The machine:
cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 10 (buster)"
NAME="Debian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
caddy -validate
Serving HTTPS on port 443
https://federicod.dev
Serving HTTP on port 80
http://federicod.dev
WARNING: File descriptor limit 1024 is too low for production servers. At least 8192 is recommended. Fix with `ulimit -n 8192`.
none
d. My complete Caddyfile:
⋊> ~/caddy cat Caddyfile        21:14:47
#veronamusical.federicod.dev {
#       proxy / 192.168.1.6:8000 {
#               transparent
#       log veronamusical-seafile.log {
#               rotate_size 10
#               rotate_age  14
#               rotate_keep 20
#               rotate_compress
federicod.dev {
        root /root/caddy/test
I expect to be served the index.html under the root provided. Instead, I receive an ERR_SSL_PROTOCOL_ERROR.
curl -IL http://federicod.dev
HTTP/1.1 301 Moved Permanently
Connection: close
Content-Type: text/html; charset=utf-8
Server: Caddy
Date: Mon, 13 Jan 2020 20:21:24 GMT
curl: (35) error:1408F10B:SSL routines:ssl3_get_record:wrong version number
I’ve tried to change the Caddyfile to serve the domain on port 80 and disabling tls, in the browser I get the same error, however, with curl I get:
HTTP/1.1 200 OK
Accept-Ranges: bytes
Content-Length: 11
Etag: "q422pkb"
Last-Modified: Mon, 13 Jan 2020 17:17:44 GMT
Server: Caddy
Date: Mon, 13 Jan 2020 20:18:18 GMT
With Firefox the error shown instead is: SSL_ERROR_RX_RECORD_TOO_LONG
I can’t access the site at all right now, connection refused on both ports.
Was there some kind of proxy in front of your server at all, maybe?
Is port forwarding in play here? Do you have both 80 and 443 forwarded to the same machine?
In between each try I didn’t left caddy running so it’s ok that you had a connection refused.
There is port forwarding enabled 80-80 443-443 and there aren’t proxies. Both ports are forwarded to a proxmox host.
One last try I did was to swap out the domain name with the public IP and TLS off and the test page was served correctly.
publicip:80 {
    root ...
    tls off
EDIT
I did leave the caddy service running in case you needed to further inspect the issue by querying the domain.
I also doubted my DNS configuration over Google Domains (@ A 1H 93.49.98.183) and tried a free subdomain at duckdns but I get the same issue so I suspect troubles are in my host\caddy. now the Caddyfile is:
root@caddy:~# cat caddy/Caddyfile
    federicod.dev {
        root /var/www/test
*:80 {
        root /var/www/test
        tls off
federicod.duckdns.org {
        root /var/www/test
EDIT 2
Upon further investigating I discovered the command line command openssl s_client -connect federicod.dev:443 and got:
root@caddy:~/caddy# openssl s_client -connect federicod.dev:443
CONNECTED(00000006)
139799956910528:error:1408F10B:SSL routines:ssl3_get_record:wrong version number:../ssl/record/ssl3_record.c:332:
no peer certificate available
No client certificate CA names sent
SSL handshake has read 5 bytes and written 293 bytes
Verification: OK
New, (NONE), Cipher is (NONE)
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
    Protocol  : TLSv1.3
    Cipher    : 0000
    Session-ID:
    Session-ID-ctx:
    Resumption PSK:
    PSK identity: None
    PSK identity hint: None
    SRP username: None
    Start Time: 1579024459
    Timeout   : 7200 (sec)
    Verify return code: 0 (ok)
    Extended master secret: no
    Max Early Data: 0
EDIT 3
I’ve also tried to obtain myself the SSL certificates following the instructions here and edited the Caddyfile accordingly with no success.
federicod.dev:80, federicod.dev:443 {
        root /var/www/test
        tls /etc/letsencrypt/live/federicod.dev/fullchain.pem /etc/letsencrypt/live/federicod.dev/privkey.pem
Is Caddy running directly on the Proxmox host or in a guest VM / container?
The more I think about it, the more I reckon 443 is being intercepted and sent somewhere other than Caddy. I note that you have not once yet in this thread had success over port 443 regardless of what certificates or Caddy configuration you use.
My modem\router is just crap. Turns out port forwarding sometimes doesn’t work correctly, after further investigating the issue as you suggested it was a networking issue. Tried with other hardware and everything worked like plug-n-play.
