matty111
(Matty111)
1
Hi,
I have many microservices in docker on 8080 port and a ui angular.
My caddyfile is:
localhost
handle /app1/* {
Reverseproxy app1:8080
handle /* {
Reverseproxy ui:8080
My ui can’t call backend microservice and return ERR INVALID REDIRECT.
My microservices are all in localhost on 80 port with this caddyfile
Please fill out the entire help thread template, there’s not enough information here to help.
What are in your Caddy logs, what’s your full, unredacted Caddyfile? If you use curl -v
to make the request, what do you see?
system
(system)
Closed
3
