v2.2.1
Ubuntu 18.04.5 LTS (94.15.0-121-generic)
paste command here
# email to use on Let's Encrypt
email <email>
# Uncomment for debug
#acme_ca https://acme-staging-v02.api.letsencrypt.org/directory
#debug
# Add gzip compression to requests
(webconf) {
# Add forward headers to requests
(theheaders) {
header_up X-Forwarded-Ssl on
header_up Host {host}
header_up X-Real-IP {remote}
header_up X-Url-Scheme {scheme}
build.joycraft-games.com:49946 {
redir 172.15.1.3:49946
build.joycraft-games.com {
reverse_proxy http://172.16.1.3:8080 {
import theheaders
import webconf
# enable access log for build
output file /var/log/caddy-build.log
svn.joycraft-games.com {
reverse_proxy http://172.16.1.4 {
import theheaders
import webconf
doc.joycraft-games.com {
reverse_proxy http://172.16.1.8:80 {
import theheaders
import webconf
ftp.joycraft-games.com {
reverse_proxy http://172.16.1.5 {
import theheaders
import webconf
box.joycraft-games.com {
reverse_proxy http://172.16.1.2:80 {
import theheaders
header_down Strict-Transport-Security "max-age=15552000;"
header_down Referrer-Policy "strict-origin-when-cross-origin"
header_down X-XSS-Protection "1; mode=block"
header_down X-Content-Type-Options "nosniff"
header_down X-Frame-Options "SAMEORIGIN"
import webconf
#enable access log for box
output file /var/log/caddy-box.log
jcgbuild.ddns.net {
import theheaders
import webconf
For last 3 days I see weird behavior on google chrome in local network.outside local network everything is working great, and inside local network everything is working too if I use any browser other than chrome based, like firefox, safari, opera, IE. But if I’ll try to access sites using Chrome or Edge there are high chances to get ERR_CONNECTION_REFUSED for every request or sometimes get successful connection for first site and then same error code for every other sites. Sometimes restarting Chrome or whole PC helps, but after a few hours ERR_CONNECTION_REFUSED appears again.
Have no clue where to put my router config info, so I’ll use this section.
For local network I have internal DNS server redirecting every domain listed in CaddyFile to 172.16.1.1 (Caddy’s IP address)
For the Internet I have every incoming 80 and 443 packet redirected to same IP.
I had Caddy v.2.2.0 running but after update to 2.2.1 nothing changed.
I’ve tried to enable logging to see what’s going on on server side (as you can see in CaddyFile for build.joycraft-games.com and box.joycraft-games.com) but Caddy unable/doesn’t want to create the log files.
