Err_connection_refused 443
### 1. Caddy version (`caddy version`):
`v2.4.5 h1:P1mRs6V2cMcagSPn+NWpD+OEYUYLIf6ecOa48cFGeUg=`
### 2. How I run Caddy:
`Public vps server`
#### a. System environment:
`ubuntu 20.04`
Paste command here.
caddy reverse-proxy --from netwerk.tech --to localhost:10000
#### c. Service/unit/compose file:
`Docker > works if i run caddy with caddy reverse-proxy --from netwerk.tech --to localhost:10000`
# domain name.
netwerk.tech:80 {
        root * /usr/share/caddy
        reverse_proxy localhost:10000
        # php_fastcgi localhost:9000
{"apps":{"http":{"servers":{"srv0":{"listen":[":80"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"vars","root":"/usr/share/caddy"},{"handler":"reverse_proxy","upstreams":[{"dial":"localhost:10000"}]},{"handler":"file_server","hide":["./Caddyfi>
If i run caddy with caddy start reverse proxy does not seems to work
when i stop caddy and run the lower command, my docker container works…
### 4. Error messages and/or full log output:
sep 15 16:25:13 h2949204.stratoserver.net caddy[110940]: LOGNAME=caddy
sep 15 16:25:13 h2949204.stratoserver.net caddy[110940]: USER=caddy
sep 15 16:25:13 h2949204.stratoserver.net caddy[110940]: INVOCATION_ID=f1d037ce203d4bab8be76f8031c90a20
sep 15 16:25:13 h2949204.stratoserver.net caddy[110940]: JOURNAL_STREAM=8:4294461196
sep 15 16:25:13 h2949204.stratoserver.net caddy[110940]: {"level":"info","ts":1631715913.4884837,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
sep 15 16:25:13 h2949204.stratoserver.net caddy[110940]: {"level":"warn","ts":1631715913.4894576,"msg":"input is not formatted with 'caddy fmt'","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":1}
sep 15 16:25:13 h2949204.stratoserver.net caddy[110940]: run: loading initial config: loading new config: starting caddy administration endpoint: listen tcp 127.0.0.1:2019: bind: address already in use
sep 15 16:25:13 h2949204.stratoserver.net systemd[1]: Started Caddy.
sep 15 16:25:13 h2949204.stratoserver.net systemd[1]: caddy.service: Main process exited, code=exited, status=1/FAILURE
sep 15 16:25:13 h2949204.stratoserver.net systemd[1]: caddy.service: Failed with result 'exit-code'.
unbind port 2019
full reboot
The formatting of your post is all broken. Please fix it! It’s very difficult to read. I suggest trying again from the help topic template. Please follow the instructions, and make sure there aren’t extra ``` (code fences) inserted when pasting, which break the formatting.
I’m very sorry, i’m new to this… i think its better now?
There’s missing some details. How did you install Caddy, exactly?
Essentially, you’re trying to run a second instance of Caddy while one is already running.
Indeed, but even when i stop and restart the service (caddy), it’s keeping this error… i look in to this :slight_smile:
Again, how did you install Caddy, exactly? That’s key to helping you here.
I just follewed the Install — Caddy Documentation without doing edits…
https://docs.budibase.com/self-hosting/advanced-options/reverse-proxy
This was recomended after installing Get started - Budibase Docs (docker)
If you installed Caddy this way, then Caddy will already be running as a systemd service.
You should modify the Caddyfile at /etc/caddy/Caddyfile to do what you need.
Don’t use the caddy reverse-proxy command, that’s meant for development on your local machine when you just need something quick to spin up.
Those budibase docs should not recommend using caddy reverse-proxy.
Please make sure to also read this page in the docs:
Ok i adjusted the
to
netwerk.tech {
tls xxx
#log
i’ll reboot and check if it’s running automatic now…
Thank you :slight_smile:
The handle is redundant in this case.
Also, make sure to use backticks ``` on the lines before and after your config, to use code formatting when posting on the forums. It’s important, so that it’s easy to read, and so whitespace is preserved.
All you need, probably, is this:
netwerk.tech {
Thanks :slight_smile: i reinstalled caddy and will try this comf :slight_smile:
Thanks for all the help :slight_smile: everything is working now :slight_smile:
