Hey Caddy community! I appreciate all your time and help. Happy to provide any additional information. My goal is to replace my current working usage of Nginx with Caddy. I did not ever get TLS/HTTPs working with Nginx, so I figured using Caddy to do automatic TLS would be a fun experiment.
My goal is to use Caddy to create useful subdomains for the many applications I’m running on an Unraid machine. The machine is only accessible on the local network or through a static IP that’s only available through a VPN. I do not have this machine exposed to the internet, the VPN is required.
Rather than remember the static IP and various ports, I currently use Nginx to use subdomains for ease of usage and would love to replace it with Caddy with TLS.
I’m cofident I’m making a silly mistake, either with my caddyfile or the DNS setup that worked with Nginx requires a tweak to work with Caddy…
2.3.0
Running on an Unraid server using the latest caddy:alpine Docker image.
Since I’m using Unraid, I simply click on the Caddy2 icon and ask it to run.
Again, since its Unraid, I’m using their GUI to configure the service. I’ll transcribe all the contents of the GUI here.
- name: CaddyV2
- repository:
caddy:alpine - network type:
Bridge - console shell command:
Shell - Privileged:
off - HTTP:
80- Container Port:
80
- Container Port:
- HTTPS:
443- Container Port:
443
- Container Port:
- Data:
/mnt/user/Docker/conf/caddyv2/data- Container Path:
/data
- Container Path:
- Config:
/mnt/user/appdata/CaddyV2- Container Path:
/config
- Container Path:
- Caddyfile:
/mnt/user/Docker/conf/caddyv2/Caddyfile/caddyfile
# Uncomment for debug
unraid.grehg.xyz {
reverse_proxy 172.24.0.2:8080
I’m trying to replace my working usage of Nginx with Caddyv2. I’m interested in using Caddyv2 for the HTTPS/Let’s Encrypt automatic configuration.
When starting the Docker container described above, I’m experiencing a Secure Connection Failed.
The following error message is displayed in my Firefox web browser when navigating to unraid.grehg.xyz
An error occurred during a connection to unraid.grehg.xyz. Peer reports it experienced an internal error.
Error code: SSL_ERROR_INTERNAL_ERROR_ALERT
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
Please contact the website owners to inform them of this problem.
The following logs can are produced from the Caddyv2 container:
{"level":"info","ts":1613311362.6244876,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"info","ts":1613311362.6271276,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
{"level":"info","ts":1613311362.6274478,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0003d2460"}
{"level":"info","ts":1613311362.7414167,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1613311362.7414553,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"info","ts":1613311362.7449307,"logger":"tls","msg":"cleaned up storage units"}
{"level":"info","ts":1613311362.7496035,"msg":"autosaved config","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1613311362.749628,"msg":"serving initial configuration"}
{"level":"info","ts":1613311362.7896144,"logger":"tls.obtain","msg":"acquiring lock","identifier":"unraid.grehg.xyz"}
{"level":"info","ts":1613311362.7908468,"logger":"tls.obtain","msg":"lock acquired","identifier":"unraid.grehg.xyz"}
{"level":"info","ts":1613311362.8358848,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["unraid.grehg.xyz"]}
{"level":"info","ts":1613311362.8359134,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["unraid.grehg.xyz"]}
{"level":"info","ts":1613311363.621296,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"unraid.grehg.xyz","challenge_type":"tls-alpn-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
{"level":"error","ts":1613311364.1144583,"logger":"tls.issuance.acme.acme_client","msg":"challenge failed","identifier":"unraid.grehg.xyz","challenge_type":"tls-alpn-01","status_code":400,"problem_type":"urn:ietf:params:acme:error:dns","error":"No valid IP addresses found for unraid.grehg.xyz"}
{"level":"error","ts":1613311364.1144931,"logger":"tls.issuance.acme.acme_client","msg":"validating authorization","identifier":"unraid.grehg.xyz","error":"authorization failed: HTTP 400 urn:ietf:params:acme:error:dns - No valid IP addresses found for unraid.grehg.xyz","order":"https://acme-v02.api.letsencrypt.org/acme/order/112437493/7904505438","attempt":1,"max_attempts":3}
{"level":"info","ts":1613311365.317856,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"unraid.grehg.xyz","challenge_type":"http-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
{"level":"error","ts":1613311365.7185018,"logger":"tls.issuance.acme.acme_client","msg":"challenge failed","identifier":"unraid.grehg.xyz","challenge_type":"http-01","status_code":400,"problem_type":"urn:ietf:params:acme:error:dns","error":"No valid IP addresses found for unraid.grehg.xyz"}
{"level":"error","ts":1613311365.718539,"logger":"tls.issuance.acme.acme_client","msg":"validating authorization","identifier":"unraid.grehg.xyz","error":"authorization failed: HTTP 400 urn:ietf:params:acme:error:dns - No valid IP addresses found for unraid.grehg.xyz","order":"https://acme-v02.api.letsencrypt.org/acme/order/112437493/7904505831","attempt":2,"max_attempts":3}
{"level":"info","ts":1613311367.046424,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["unraid.grehg.xyz"]}
{"level":"info","ts":1613311367.0465088,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["unraid.grehg.xyz"]}
{"level":"info","ts":1613311368.7006106,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"unraid.grehg.xyz","challenge_type":"http-01","ca":"https://acme.zerossl.com/v2/DV90"}
{"level":"error","ts":1613311669.6372132,"logger":"tls.obtain","msg":"will retry","error":"[unraid.grehg.xyz] Obtain: [unraid.grehg.xyz] solving challenges: [unraid.grehg.xyz] authorization took too long (order=https://acme.zerossl.com/v2/DV90/order/2au2eUN-pdrwoJ23UhYhwQ) (ca=https://acme.zerossl.com/v2/DV90)","attempt":1,"retrying_in":60,"elapsed":306.846336473,"max_duration":2592000}
{"level":"info","ts":1613311730.295023,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"unraid.grehg.xyz","challenge_type":"http-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
{"level":"error","ts":1613311731.3704333,"logger":"tls.issuance.acme.acme_client","msg":"challenge failed","identifier":"unraid.grehg.xyz","challenge_type":"http-01","status_code":400,"problem_type":"urn:ietf:params:acme:error:dns","error":"No valid IP addresses found for unraid.grehg.xyz"}
{"level":"error","ts":1613311731.3705115,"logger":"tls.issuance.acme.acme_client","msg":"validating authorization","identifier":"unraid.grehg.xyz","error":"authorization failed: HTTP 400 urn:ietf:params:acme:error:dns - No valid IP addresses found for unraid.grehg.xyz","order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/18042893/240263624","attempt":1,"max_attempts":3}
{"level":"info","ts":1613311732.7081492,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"unraid.grehg.xyz","challenge_type":"tls-alpn-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
{"level":"error","ts":1613311733.236309,"logger":"tls.issuance.acme.acme_client","msg":"challenge failed","identifier":"unraid.grehg.xyz","challenge_type":"tls-alpn-01","status_code":400,"problem_type":"urn:ietf:params:acme:error:dns","error":"No valid IP addresses found for unraid.grehg.xyz"}
{"level":"error","ts":1613311733.236349,"logger":"tls.issuance.acme.acme_client","msg":"validating authorization","identifier":"unraid.grehg.xyz","error":"authorization failed: HTTP 400 urn:ietf:params:acme:error:dns - No valid IP addresses found for unraid.grehg.xyz","order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/18042893/240263645","attempt":2,"max_attempts":3}
{"level":"info","ts":1613311735.7454767,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"unraid.grehg.xyz","challenge_type":"http-01","ca":"https://acme.zerossl.com/v2/DV90"}
{"level":"error","ts":1613312037.0335948,"logger":"tls.obtain","msg":"will retry","error":"[unraid.grehg.xyz] Obtain: [unraid.grehg.xyz] solving challenges: [unraid.grehg.xyz] authorization took too long (order=https://acme.zerossl.com/v2/DV90/order/ir_NM9bXM7kk9zkzi9lAXw) (ca=https://acme.zerossl.com/v2/DV90)","attempt":2,"retrying_in":120,"elapsed":674.242720478,"max_duration":2592000}
{"level":"info","ts":1613312157.5465395,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"unraid.grehg.xyz","challenge_type":"http-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
{"level":"error","ts":1613312157.9624379,"logger":"tls.issuance.acme.acme_client","msg":"challenge failed","identifier":"unraid.grehg.xyz","challenge_type":"http-01","status_code":400,"problem_type":"urn:ietf:params:acme:error:dns","error":"No valid IP addresses found for unraid.grehg.xyz"}
{"level":"error","ts":1613312157.9624746,"logger":"tls.issuance.acme.acme_client","msg":"validating authorization","identifier":"unraid.grehg.xyz","error":"authorization failed: HTTP 400 urn:ietf:params:acme:error:dns - No valid IP addresses found for unraid.grehg.xyz","order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/18042893/240267115","attempt":1,"max_attempts":3}
{"level":"info","ts":1613312159.139391,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"unraid.grehg.xyz","challenge_type":"tls-alpn-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
{"level":"error","ts":1613312159.745343,"logger":"tls.issuance.acme.acme_client","msg":"challenge failed","identifier":"unraid.grehg.xyz","challenge_type":"tls-alpn-01","status_code":400,"problem_type":"urn:ietf:params:acme:error:dns","error":"No valid IP addresses found for unraid.grehg.xyz"}
{"level":"error","ts":1613312159.7453814,"logger":"tls.issuance.acme.acme_client","msg":"validating authorization","identifier":"unraid.grehg.xyz","error":"authorization failed: HTTP 400 urn:ietf:params:acme:error:dns - No valid IP addresses found for unraid.grehg.xyz","order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/18042893/240267131","attempt":2,"max_attempts":3}
{"level":"info","ts":1613312162.2983823,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"unraid.grehg.xyz","challenge_type":"http-01","ca":"https://acme.zerossl.com/v2/DV90"}
{"level":"error","ts":1613312463.4226704,"logger":"tls.obtain","msg":"will retry","error":"[unraid.grehg.xyz] Obtain: [unraid.grehg.xyz] solving challenges: [unraid.grehg.xyz] authorization took too long (order=https://acme.zerossl.com/v2/DV90/order/t8FQdv9FM075kQWoFDC8Pg) (ca=https://acme.zerossl.com/v2/DV90)","attempt":3,"retrying_in":120,"elapsed":1100.631795524,"max_duration":2592000}
{"level":"info","ts":1613312584.0692773,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"unraid.grehg.xyz","challenge_type":"http-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
{"level":"error","ts":1613312584.5004144,"logger":"tls.issuance.acme.acme_client","msg":"challenge failed","identifier":"unraid.grehg.xyz","challenge_type":"http-01","status_code":400,"problem_type":"urn:ietf:params:acme:error:dns","error":"No valid IP addresses found for unraid.grehg.xyz"}
{"level":"error","ts":1613312584.5004644,"logger":"tls.issuance.acme.acme_client","msg":"validating authorization","identifier":"unraid.grehg.xyz","error":"authorization failed: HTTP 400 urn:ietf:params:acme:error:dns - No valid IP addresses found for unraid.grehg.xyz","order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/18042893/240270470","attempt":1,"max_attempts":3}
{"level":"info","ts":1613312585.6766846,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"unraid.grehg.xyz","challenge_type":"tls-alpn-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
{"level":"error","ts":1613312586.0910618,"logger":"tls.issuance.acme.acme_client","msg":"challenge failed","identifier":"unraid.grehg.xyz","challenge_type":"tls-alpn-01","status_code":400,"problem_type":"urn:ietf:params:acme:error:dns","error":"No valid IP addresses found for unraid.grehg.xyz"}
{"level":"error","ts":1613312586.0910912,"logger":"tls.issuance.acme.acme_client","msg":"validating authorization","identifier":"unraid.grehg.xyz","error":"authorization failed: HTTP 400 urn:ietf:params:acme:error:dns - No valid IP addresses found for unraid.grehg.xyz","order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/18042893/240270480","attempt":2,"max_attempts":3}
{"level":"info","ts":1613312588.8719897,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"unraid.grehg.xyz","challenge_type":"http-01","ca":"https://acme.zerossl.com/v2/DV90"}
{"level":"error","ts":1613312892.7510471,"logger":"tls.obtain","msg":"will retry","error":"[unraid.grehg.xyz] Obtain: [unraid.grehg.xyz] solving challenges: [unraid.grehg.xyz] authorization took too long (order=https://acme.zerossl.com/v2/DV90/order/oLJyVzhWkG06iqryuTPfwQ) (ca=https://acme.zerossl.com/v2/DV90)","attempt":4,"retrying_in":300,"elapsed":1529.960170603,"max_duration":2592000}
{"level":"info","ts":1613313194.5689545,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"unraid.grehg.xyz","challenge_type":"http-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
{"level":"error","ts":1613313194.9773667,"logger":"tls.issuance.acme.acme_client","msg":"challenge failed","identifier":"unraid.grehg.xyz","challenge_type":"http-01","status_code":400,"problem_type":"urn:ietf:params:acme:error:dns","error":"No valid IP addresses found for unraid.grehg.xyz"}
{"level":"error","ts":1613313194.9774048,"logger":"tls.issuance.acme.acme_client","msg":"validating authorization","identifier":"unraid.grehg.xyz","error":"authorization failed: HTTP 400 urn:ietf:params:acme:error:dns - No valid IP addresses found for unraid.grehg.xyz","order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/18042893/240274456","attempt":1,"max_attempts":3}
{"level":"info","ts":1613313196.156005,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"unraid.grehg.xyz","challenge_type":"tls-alpn-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
{"level":"error","ts":1613313196.5727189,"logger":"tls.issuance.acme.acme_client","msg":"challenge failed","identifier":"unraid.grehg.xyz","challenge_type":"tls-alpn-01","status_code":400,"problem_type":"urn:ietf:params:acme:error:dns","error":"No valid IP addresses found for unraid.grehg.xyz"}
{"level":"error","ts":1613313196.5727549,"logger":"tls.issuance.acme.acme_client","msg":"validating authorization","identifier":"unraid.grehg.xyz","error":"authorization failed: HTTP 400 urn:ietf:params:acme:error:dns - No valid IP addresses found for unraid.grehg.xyz","order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/18042893/240274470","attempt":2,"max_attempts":3}
{"level":"info","ts":1613313199.4684935,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"unraid.grehg.xyz","challenge_type":"http-01","ca":"https://acme.zerossl.com/v2/DV90"}
{"level":"error","ts":1613313500.3908622,"logger":"tls.obtain","msg":"will retry","error":"[unraid.grehg.xyz] Obtain: [unraid.grehg.xyz] solving challenges: [unraid.grehg.xyz] authorization took too long (order=https://acme.zerossl.com/v2/DV90/order/IoQ6vuhG8Yea-ArP_1R1mQ) (ca=https://acme.zerossl.com/v2/DV90)","attempt":5,"retrying_in":600,"elapsed":2137.59998557,"max_duration":2592000}
{"level":"info","ts":1613313889.3462927,"msg":"shutting down apps then terminating","signal":"SIGTERM"}
{"level":"info","ts":1613313890.3848588,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc0003d2460"}
{"level":"info","ts":1613313890.384885,"logger":"tls.obtain","msg":"releasing lock","identifier":"unraid.grehg.xyz"}
{"level":"error","ts":1613313890.3861017,"logger":"tls","msg":"job failed","error":"unraid.grehg.xyz: obtaining certificate: context canceled"}
I’ve turne don debugging to see if I can find any additional information.
I’ve checked my DNS, from Namecheap, and everything looks correct there. Again, I have a working Nginx setup, so I imagine the DNS is configured correctly. For completion. here is what my DNS looks like:
| Type | Host | Value | TTL |
| A Record | @ | 172.24.0.2 | Automatic |
| CNAME Record | * | grehg.xyz | Automatic |
