Environment Variables
Hi. How do I add environment variables in the code. For example I want to get data from .env?
Not sure what you mean by “code”, but if you’re asking about Caddyfile:
Do I need to modify from bash? As when I do it according to the documentation it throws error
No idea what you’re doing. Could you share your configuration and the exact error you’re getting?
For example I have this .env variable DOMAIN_NAME = *.test *.smth . In CADDYFILE now I have hardcoded values path *.test *.smth which works now but I need to make it path {$DOMAIN_NAME} which doesn’t work for now.
It’s really hard to help without seeing the actual configuration you’re running. At this point, it’s all guesswork, and honestly, it’s getting a bit tiring trying to figure out what you’re actually doing.
If you can share a concrete example or config, I’ll be happy to take another look. Otherwise, this might be my last reply on this one.
Here’s an example Caddyfile:
	http_port 8080
{$DOMAIN_NAME:localhost:8080} {
	respond "{host} is alive!"
http:// {
	respond "default is alive!"
Running it with:
$ DOMAIN_NAME="*.test:8080, *.smth:8080" caddy run --config Caddyfile
Produces this autosave.json:
$ cat autosave.json | jq .
  "apps": {
    "http": {
      "http_port": 8080,
      "servers": {
        "srv0": {
          "listen": [
            ":8080"
          "routes": [
              "handle": [
                  "handler": "subroute",
                  "routes": [
                      "handle": [
                          "body": "{http.request.host} is alive!",
                          "handler": "static_response"
              "match": [
                  "host": [
                    "*.test",
                    "*.smth"
              "terminal": true
              "handle": [
                  "routes": [
                      "handle": [
                          "body": "default is alive!",
              "terminal": true
And the test results:
$ curl http://127.0.0.1:8080 -H 'Host: foo.test'
foo.test is alive!
$ curl http://127.0.0.1:8080 -H 'Host: bar.smth'
bar.smth is alive!
curl http://127.0.0.1:8080 -H 'Host: example.com'
default is alive!
So yep, the environment variable gets picked up by Caddy just fine.
This topic was automatically closed after 60 days. New replies are no longer allowed.
