1. Output of caddy version
v2.6.2
2. running caddy via docker
docker-compose.yml
build:
context: .
dockerfile: ./Docker/compose/local/caddy/Dockerfile
image: caddy
- ADMIN_URL=secreturl
- 443:443/tcp
- 443:443/udp
- ./Docker/compose/local/caddy/Caddyfile:/etc/caddy/Caddyfile
- ./Docker/compose/local/caddy/common:/srv/common
- caddy_data:/data
- caddy_config:/config
- ./certs:/certs
3. Question
How can I use env variables inside templates?
I found few clues on the forum and docs, but nothing worked.
It does work in Caddyfile, but not in html template.
I tried
<h1>{{env "ADMIN_URL"}}</h1>
<h1>{{.Env.ADMIN_URL}}</h1>
<h1>{{.Env "ADMIN_URL"}}</h1>
thank you
