2.4.6
Via docker compose con Amazon ECS.
Amazon ECS, Fargate. Docker compose file with docker client using ECS context.
Caddyfile
is base64 encoded in and environment variable. Then is decoded and copied to /etc/caddy/Caddyfile
. Then caddy run --config /etc/caddy/Caddyfile --adapter caddyfile
image: caddy:2.4.6-alpine
- "2345:2345"
- caddy_data:/data
- caddy_config:/config
command: ["sh", "-c", "echo ${CADDYFILE_B64} | base64 -d > /etc/caddy/Caddyfile && caddy run --config /etc/caddy/Caddyfile --adapter caddyfile"]
caddy_data:
caddy_config:
https://example.example.com {
reverse_proxy http://localhost:1234
https://example.example.com:2345 {
reverse_proxy http://localhost:2345
When we do go to http://example.example.com/, we get redirected to https://example.example.com:2345/ instead of https://example.example.com:1234/.
% curl -IL http://example.example.com
HTTP/1.1 308 Permanent Redirect
Connection: close
Server: Caddy
Date: Wed, 12 Jan 2022 14:57:00 GMT
HTTP/2 200
content-type: application/octet-stream
date: Wed, 12 Jan 2022 14:57:00 GMT
server: Caddy
content-length: 0
Tried changing the order of the entries.
