Ubuntu 20.04
caddy2 run --watch --config Caddyfile
order realip first
http:// {
root * /var/www/webapp
uri /api/* strip_prefix /api
reverse_proxy /api/* http://httpbin.org {
header_up X-Forwarded-For {remote_host}
@assets path *.js *.css *.png *.svg
header @assets Cache-Control "public; max-age=604800"
I’m trying to write a Caddyfile for a setup that serves content from an API server under /api
and a typical PHP webapp with certain static assets otherwise. The Caddyfile contents are as above.
This work as expected; until I decided to gzip responses by adding the encode
directive as shown below, at which point caddy decides to handle all traffic using the php_fastcgi
directive.
encode {
gzip 4
Without the encode
directive, this is what happens. (I’m developing on a remote server, so I’ve used port 51541 to the server’s port 80 through SSH port forwarding):
$ curl -i http://localhost:51541/api/get
HTTP/1.1 200 OK
Access-Control-Allow-Credentials: true
Access-Control-Allow-Origin: *
Content-Length: 295
Content-Type: application/json
Date: Wed, 19 Jan 2022 05:23:59 GMT
Server: Caddy
Server: gunicorn/19.9.0
"args": {},
"headers": {
"Accept": "*/*",
"Accept-Encoding": "gzip",
"Host": "localhost",
"User-Agent": "curl/7.77.0",
"X-Amzn-Trace-Id": "Root=1-61e7a06f-178c5eb151b4f82b669408e1"
"origin": "127.0.0.1, 103.217.221.153",
"url": "http://localhost/get"
These are the debug logs generated for the request:
2022/01/19 05:30:00.518 DEBUG http.handlers.rewrite rewrote request {"request": {"remote_addr": "127.0.0.1:60390", "proto": "HTTP/1.1", "method": "GET", "host": "localhost:51541", "uri": "/api/get", "headers": {"User-Agent": ["curl/7.77.0"], "Accept": ["*/*"]}}, "method": "GET", "uri": "/get"}
2022/01/19 05:30:01.777 DEBUG http.handlers.reverse_proxy upstream roundtrip {"upstream": "httpbin.org:80", "duration": 1.258933302, "request": {"remote_addr": "127.0.0.1:60390", "proto": "HTTP/1.1", "method": "GET", "host": "localhost:51541", "uri": "/get", "headers": {"User-Agent": ["curl/7.77.0"], "Accept": ["*/*"], "X-Forwarded-Proto": ["http"], "X-Forwarded-For": ["127.0.0.1"]}}, "headers": {"Server": ["gunicorn/19.9.0"], "Access-Control-Allow-Origin": ["*"], "Access-Control-Allow-Credentials": ["true"], "Date": ["Wed, 19 Jan 2022 05:30:01 GMT"], "Content-Type": ["application/json"], "Content-Length": ["295"], "Connection": ["keep-alive"]}, "status": 200}
With encode
enabled, this is what happens instead. Notice the PHPSESSID
cookie indicating that the request was handled by the PHP-FPM server instead:
HTTP/1.1 404 Not Found
Cache-Control: max-age=0, private, must-revalidate
Cache-Control: no-cache, private
Content-Security-Policy: frame-ancestors 'self'
Content-Type: text/html; charset=UTF-8
Date: Wed, 19 Jan 2022 05:31:49 GMT
Server: Caddy
Set-Cookie: PHPSESSID=gk1p5d4nlbm11tac5fn7i93ha8anqqht; path=/; HttpOnly; SameSite=lax
Status: 404 Not Found
X-Frame-Options: sameorigin
Content-Length: 9
Not Found
These are the corresponding debug logs generated with encode
enabled, which apparently indicate that the /get
request is now being passed to the php_fastcgi handler:
2022/01/19 05:31:49.492 DEBUG http.handlers.rewrite rewrote request {"request": {"remote_addr": "127.0.0.1:44002", "proto": "HTTP/1.1", "method": "GET", "host": "localhost:51541", "uri": "/api/get", "headers": {"User-Agent": ["curl/7.77.0"], "Accept": ["*/*"]}}, "method": "GET", "uri": "/get"}
2022/01/19 05:31:49.492 DEBUG http.handlers.rewrite rewrote request {"request": {"remote_addr": "127.0.0.1:44002", "proto": "HTTP/1.1", "method": "GET", "host": "localhost:51541", "uri": "/get", "headers": {"User-Agent": ["curl/7.77.0"], "Accept": ["*/*"]}}, "method": "GET", "uri": "index.php"}
2022/01/19 05:31:49.492 DEBUG http.reverse_proxy.transport.fastcgi roundtrip {"request": {"remote_addr": "127.0.0.1:44002", "proto": "HTTP/1.1", "method": "GET", "host": "localhost:51541", "uri": "index.php", "headers": {"Accept": ["*/*"], "X-Forwarded-Proto": ["http"], "X-Forwarded-For": ["127.0.0.1"], "User-Agent": ["curl/7.77.0"]}}, "dial": "/run/php/php7.4-fpm.sock", "env": {"AUTH_TYPE":"","CONTENT_LENGTH":"","CONTENT_TYPE":"","DOCUMENT_ROOT":"/var/www/webapp","DOCUMENT_URI":"index.php","GATEWAY_INTERFACE":"CGI/1.1","HTTP_ACCEPT":"*/*","HTTP_HOST":"localhost:51541","HTTP_USER_AGENT":"curl/7.77.0","HTTP_X_FORWARDED_FOR":"127.0.0.1","HTTP_X_FORWARDED_PROTO":"http","PATH_INFO":"","QUERY_STRING":"","REMOTE_ADDR":"127.0.0.1","REMOTE_HOST":"127.0.0.1","REMOTE_IDENT":"","REMOTE_PORT":"44002","REMOTE_USER":"","REQUEST_METHOD":"GET","REQUEST_SCHEME":"http","REQUEST_URI":"/api/get","SCRIPT_FILENAME":"/var/www/webapp/index.php","SCRIPT_NAME":"/index.php","SERVER_NAME":"localhost","SERVER_PORT":"51541","SERVER_PROTOCOL":"HTTP/1.1","SERVER_SOFTWARE":"Caddy/v2.4.6"}}
2022/01/19 05:31:49.500 DEBUG http.handlers.reverse_proxy upstream roundtrip {"upstream": "unix//run/php/php7.4-fpm.sock", "duration": 0.007257121, "request": {"remote_addr": "127.0.0.1:44002", "proto": "HTTP/1.1", "method": "GET", "host": "localhost:51541", "uri": "index.php", "headers": {"X-Forwarded-For": ["127.0.0.1"], "User-Agent": ["curl/7.77.0"], "Accept": ["*/*"], "X-Forwarded-Proto": ["http"]}}, "headers": {"Content-Type": ["text/html; charset=UTF-8"], "Status": ["404 Not Found"], "Cache-Control": ["max-age=0, private, must-revalidate", "no-cache, private"], "Set-Cookie": ["PHPSESSID=gk1p5d4nlbm11tac5fn7i93ha8anqqht; path=/; HttpOnly; SameSite=lax"], "Date": ["Wed, 19 Jan 2022 05:31:49 GMT"], "X-Frame-Options": ["sameorigin"], "Content-Security-Policy": ["frame-ancestors 'self'"]}, "status": 404}
Shared in section 3.
I’m not sure what else to try, since encode
shouldn’t have anything to do with rewrite
, although I have a suspicion if directive orders have anything to do with it.
n/a.
