ECH not working with wildcard certificates
I am attempting to use the new encrypted client hello (ECH) functionality with my wildcard certificate domain. I followed the common Caddfile patterns for wildcard cerificates and am using the Cloudflare DNS plugin.
Unfortunately it appears that Caddy isn’t updating anything DNS wise.
{"level":"debug","ts":1745557179.799294,"logger":"tls.ech","msg":"ECH config list already published by publisher for associated domains (or no domains to publish for)","config_ids":[232],"publisher":"dns.providers.cloudflare"}
systemd service running a Proxmox Debian 12.10 LXC container
N/A
Type=notify
ExecStart=/usr/local/bin/caddy run --environ --config /etc/caddy/Caddyfile
ExecReload=/usr/local/bin/caddy reload --config /etc/caddy/Caddyfile --force
        email REDACTED
        servers {
                protocols h3 h2 h1
        dns cloudflare REDACTED
        ech ech.mydomain.com
(public_reverse_proxy) {
        reverse_proxy {args[0]} {
                        tls_trust_pool file /etc/ssl/certs/ca-certificates.crt
(private_reverse_proxy) {
        @public_ip {
                not remote_ip private_ranges
        abort @public_ip
        import public_reverse_proxy {args[0]}
*.mydomain.com {
            resolvers 1.1.1.1
            ciphers TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384 TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256 TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256
            format console
                    roll_size 10mb
                    roll_keep 10
                    roll_keep_for 168h
            Strict-Transport-Security max-age=63072000;
            X-Robots-Tag "noindex, nofollow"
            X-Frame-Options "SAMEORIGIN"
            Referrer-Policy "same-origin"
            -server
    encode {
            zstd
            br
            gzip
    @service host service.mydomain.com
    handle @service {
            import public_reverse_proxy service.internal.lan:443
        abort
It appears the core problem is that the documentation for wildcard domains hasn’t been updated to match 2.10 functionality.
Switching to the format described in New pattern for wildcard certs using Caddyfile (2.10.0) worked like a charm.
