ECH Errors with SRV records
Hi,
Trying to get ECH configured for some of my domains and get
unable to get existing DNS records to publish ECH data to HTTPS DNS record
Using Cloudflare for my DNS and have SRV records for mail purposes.
2025/04/23 10:04:21.197	ERROR	tls	unable to get existing DNS records to publish ECH data to HTTPS DNS record	{"domain": "a.yag.me.uk", "error": "parsing Cloudflare DNS record {ID:36e9811521851667f80e594bfac97894 Type:SRV Name:_imaps._tcp.yag.me.uk Content:1 993 mail.thunderweb.uk Priority:0 Proxiable:false Proxied:false TTL:1 Locked:false ZoneID: ZoneName: CreatedOn:2024-12-04 14:05:53.773381 +0000 UTC ModifiedOn:2024-12-04 14:05:53.773381 +0000 UTC Data:{LatDegrees:0 LatMinutes:0 LatSeconds:0 LatDirection: LongDegrees:0 LongMinutes:0 LongSeconds:0 LongDirection: Altitude:0 Size:0 PrecisionHorz:0 PrecisionVert:0 Service: Proto: Name: Priority:0 Weight:1 Port:993 Target:mail.thunderweb.uk Value: Tag: Flags:0 Protocol:0 Algorithm:0 KeyTag:0 DigestType:0 Usage:0 Selector:0 MatchingType:0 Content:} Meta:0xc000497ea0}: name _imaps._tcp does not contain enough fields; expected format: '_service._proto.name'"}
Docker
Dockerfile
FROM caddy:2.10-builder AS builder
RUN xcaddy build \
    --with github.com/lucaslorentz/caddy-docker-proxy/v2 \
    --with github.com/caddyserver/transform-encoder \
    --with github.com/WeidiDeng/caddy-cloudflare-ip
FROM caddy:2.10
RUN apk add --no-cache bash nano git tzdata
CMD ["caddy", "docker-proxy"]
- name: install caddy on docker1
  hosts: docker1.srv.3fr.uk
  gather_facts: false
  tasks:
    - community.docker.docker_container:
        image: registry.srv.3fr.uk/caddy:2.10.0
        pull: true
        hostname: caddy
        restart_policy: always
        default_host_ip: ""
        dns_servers:
          - 8.8.8.8
          - 1.1.1.1
          - 8.8.4.4
          - name: web
        env:
          PUID: "1000"
          PGID: "1000"
          TZ: "Europe/London"
          CADDY_DOCKER_CADDYFILE_PATH: "/config/caddy.static"
          CF_API_TOKEN:  "{{ cloudflare_api }}"
          - caddy_config:/config
          - caddy_data:/data
          - wordpress_data:/var/www/html
          - "443:443/udp"
        http_port 80
        email ssl@thunderweb.co.uk
        log default {
                output stdout
                format console
        servers :443 {
                protocols h1 h2 h3
                trusted_proxies cloudflare {
                        interval 12h
                        timeout 15s
        dns cloudflare {env.CF_API_TOKEN}
        ech home.thunderweb.uk
(httpauth) {
        forward_auth authelia:9091 {
                uri /api/authz/forward-auth
                copy_headers Remote-User Remote-Groups Remote-Email Remote-Name
yag.home.thunderweb.uk:443 {
        import httpauth
        root * /data/static/yag.me.uk/admin/public_html/
a.yag.me.uk:443 {
        redir / https://yag.home.thunderweb.uk
Already fixed at Support 2-label SRV names (fix #163) by mholt · Pull Request #164 · libdns/libdns · GitHub – you can build with that commit now, or you can wait until the next patch release of Caddy (but since you’re already making a custom build, why wait?)
xcaddy build --with github.com/libdns/libdns@master
Great; thanks Matt! :slight_smile:
